Ana içeriğe geç
Kindle Touch Bezel Replacement
Neye ihtiyacın var
  1. Kindle Touch Bezel Replacement, Back Cover: adım 1, 3 resimden 1. Kindle Touch Bezel Replacement, Back Cover: adım 1, 3 resimden 2. Kindle Touch Bezel Replacement, Back Cover: adım 1, 3 resimden 3.
    • Use the plastic opening tool to undo the ten plastic clips around the back panel of the Kindle.
    Wear work gloves as the tool can easily slip and stab you in the hand.
    BRUCE - Yanıt
    The clips aren't all the same; the side clips are slide-locks rather than press-locks.
    Use the Opening Tool to unclip the clips along the bottom edge. This will allow the lid to slide towards the top, releasing the side clips and allowing the lid to be lifted off.
    When reassembling, slide the lid upwards while pressing the sides to re-engage the side clips, then press the bottom edge to lock it into place.
    jimf - Yanıt
  2. Kindle Touch Bezel Replacement: adım 2, 2 resimden 1. Kindle Touch Bezel Replacement: adım 2, 2 resimden 2.
    • Gently lift the bottom and slide the panel off.
    There are four tabs on each side.The two nearest the top are open at the top, hence they slide out (back towards the power connector end.
    This is important in the reassembly stage:
    1. Align the back cover about 0.75 cm away from the top
    2. Hold the top half of the cover flat against the unit, and flex the cover away from the case a little at the bottom
    3. Slide the top and the first two clips parallel to the case
    4. snap the remaining bottom clips in place
    John Haywood - Yanıt
  3. Kindle Touch Bezel Replacement, Bezel: adım 3, 2 resimden 1. Kindle Touch Bezel Replacement, Bezel: adım 3, 2 resimden 2.
    • Using a Phillips #00 screwdriver, remove the six 4 mm screws to access the front plate.
  4. Kindle Touch Bezel Replacement: adım 4, 3 resimden 1. Kindle Touch Bezel Replacement: adım 4, 3 resimden 2. Kindle Touch Bezel Replacement: adım 4, 3 resimden 3.
    • Use the plastic opening tool to pry the bezel from the top and sides
    • The bottom of the bezel will be glued, so be careful when sliding the clips out.
    • The clips can be easily bent, so do not try to force them out. If you do bend some, they can be bent back.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Jerome Narine
221 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 19-5, Blackwell Winter 2015 USF Tampa, Team 19-5, Blackwell Winter 2015 üyesi
USFT-BLACKWELL-W15S19G5
3 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
I want to paint The bezel white. Will it come back and fit perfectly after the removal I have to make?
denianyc - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 32
Her zaman: 3,023
