Ana içeriğe geç
Kindle Touch Screen Replacement
Neye ihtiyacın var
  1. Kindle Touch Screen Replacement, Back Cover: adım 1, 3 resimden 1. Kindle Touch Screen Replacement, Back Cover: adım 1, 3 resimden 2. Kindle Touch Screen Replacement, Back Cover: adım 1, 3 resimden 3.
    • Use the plastic opening tool to undo the ten plastic clips around the back panel of the Kindle.
    Wear work gloves as the tool can easily slip and stab you in the hand.
    BRUCE - Yanıt
    The clips aren't all the same; the side clips are slide-locks rather than press-locks.
    Use the Opening Tool to unclip the clips along the bottom edge. This will allow the lid to slide towards the top, releasing the side clips and allowing the lid to be lifted off.
    When reassembling, slide the lid upwards while pressing the sides to re-engage the side clips, then press the bottom edge to lock it into place.
    jimf - Yanıt
  2. Kindle Touch Screen Replacement: adım 2, 2 resimden 1. Kindle Touch Screen Replacement: adım 2, 2 resimden 2.
    • Gently lift the bottom and slide the panel off.
    There are four tabs on each side.The two nearest the top are open at the top, hence they slide out (back towards the power connector end.
    This is important in the reassembly stage:
    1. Align the back cover about 0.75 cm away from the top
    2. Hold the top half of the cover flat against the unit, and flex the cover away from the case a little at the bottom
    3. Slide the top and the first two clips parallel to the case
    4. snap the remaining bottom clips in place
    John Haywood - Yanıt
  3. Kindle Touch Screen Replacement, Battery: adım 3, 3 resimden 1. Kindle Touch Screen Replacement, Battery: adım 3, 3 resimden 2. Kindle Touch Screen Replacement, Battery: adım 3, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove the five screws.
  4. Kindle Touch Screen Replacement: adım 4, 3 resimden 1. Kindle Touch Screen Replacement: adım 4, 3 resimden 2. Kindle Touch Screen Replacement: adım 4, 3 resimden 3.
    • Using the flat end of your spudger, gently pry the battery up and remove it.
  5. Kindle Touch Screen Replacement, Remove the 3G Board: adım 5, 3 resimden 1. Kindle Touch Screen Replacement, Remove the 3G Board: adım 5, 3 resimden 2. Kindle Touch Screen Replacement, Remove the 3G Board: adım 5, 3 resimden 3.
    • Remove the indicated four 2 mm screws with a Phillips #00 screwdriver. (Units with the 3G assembly have Phillips #000 screws.)
    • Next, gently lift the 3G assembly with a Spudger or your fingers.
    • This Kindle Touch is the WiFi only model and comes with a plastic placeholder instead of the 3G assembly.
    • Disconnect the antenna lead by carefully prying it off the 3G board with a plastic tool.
    The 3G model has an antenna connector near the top left on the underside.
    Chad Wade Day, Jr. - Yanıt
  6. Kindle Touch Screen Replacement, Bezel: adım 6, 2 resimden 1. Kindle Touch Screen Replacement, Bezel: adım 6, 2 resimden 2.
    • Using a Phillips #00 screwdriver, remove the six 4 mm screws to access the front plate.
  7. Kindle Touch Screen Replacement: adım 7, 3 resimden 1. Kindle Touch Screen Replacement: adım 7, 3 resimden 2. Kindle Touch Screen Replacement: adım 7, 3 resimden 3.
    • Use the plastic opening tool to pry the bezel from the top and sides
    • The bottom of the bezel will be glued, so be careful when sliding the clips out.
    • The clips can be easily bent, so do not try to force them out. If you do bend some, they can be bent back.
  8. Kindle Touch Screen Replacement, Rear Casing: adım 8, 1 resimden 1.
    • Use your Phillips #00 srewdriver to remove the indicated screws.
    • There are three pairs of screws that are each different. The screws on the top corners are 4 mm #00 Phillips screws, the screws on the bottom corners are 2 mm #00 Phillips screws, and the black bottom center screws are 6 mm #00 Phillips screws.
  9. Kindle Touch Screen Replacement: adım 9, 2 resimden 1. Kindle Touch Screen Replacement: adım 9, 2 resimden 2.
    • With the screws removed, gently remove the case from the internals.
  10. Kindle Touch Screen Replacement, Motherboard: adım 10, 3 resimden 1. Kindle Touch Screen Replacement, Motherboard: adım 10, 3 resimden 2. Kindle Touch Screen Replacement, Motherboard: adım 10, 3 resimden 3.
    • With the screen facing you, use your heated iOpener or other heating element to loosen the glue holding the WiFi unit to the screen. After 30 seconds, remove the heating element.
    • After the glue is loosened, use a thin tool, like a Spudger or small plastic opening tool, to separate the WiFi unit from the screen.
  11. Kindle Touch Screen Replacement: adım 11, 2 resimden 1. Kindle Touch Screen Replacement: adım 11, 2 resimden 2.
    • With the motherboard facing you, use the pointy end of your Spudger to gently separate the two speaker's connectors.
    • This connector type requires being lifted out of place, not pulled. Accidentally pulling may damage the wires.
    • During reassembly, make sure the speaker's connectors are not pushed behind the motherboard.
    • Use your #00 Phillips Screwdriver to remove the seven 2 mm screws.
  12. Kindle Touch Screen Replacement: adım 12, 3 resimden 1. Kindle Touch Screen Replacement: adım 12, 3 resimden 2. Kindle Touch Screen Replacement: adım 12, 3 resimden 3.
    • Use a Spudger to separate the display's connector from the motherboard.
    • Gently remove the motherboard from the display support.
  13. Kindle Touch Screen Replacement, Screen: adım 13, 3 resimden 1. Kindle Touch Screen Replacement, Screen: adım 13, 3 resimden 2. Kindle Touch Screen Replacement, Screen: adım 13, 3 resimden 3.
    • Using your Metal Spudger, place the pointy end into the top of the clip.
    • Gently rotate the Spudger and lift the plastic unit to create a gap on the side.
  14. Kindle Touch Screen Replacement: adım 14, 2 resimden 1. Kindle Touch Screen Replacement: adım 14, 2 resimden 2.
    • Use the Spudger in the gap to pry the clip open.
    • Repeat for the other clips.
  15. Kindle Touch Screen Replacement: adım 15, 3 resimden 1. Kindle Touch Screen Replacement: adım 15, 3 resimden 2. Kindle Touch Screen Replacement: adım 15, 3 resimden 3.
    • With the clips separated, gently guide the Screen's Motherboard Connector through the hole.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Adam Yerly
1.933 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 19-5, Blackwell Winter 2015 USF Tampa, Team 19-5, Blackwell Winter 2015 üyesi
USFT-BLACKWELL-W15S19G5
3 Üyeler
8 adet Kılavuz yazıldı
6 Yorum
I would love to know where I can get the replacement screen. Any links?
Ryan Lee - Yanıt
Good guide, thanks, finally, if you need to remove the screen itself from the black plastic frame you can do this inserting the spudger carefully between the screen and the black plastic frame and gradually moving it all round the frame. It will help if you put a heated silicon gel pack over each side before trying to release it
John Chapple - Yanıt
I have a Kindle with half of screen responding to touch
Is the touch incliduded on the screen itself? Will replacing the screen help or is there another way to fix the touch?
Mohd. Nauman Khalid - Yanıt
No, the touch circuitry is built into the motherboard.
Chris Halliwell -
Where do you buy the screen replacement part for the Kindle Touch?
Andrew Manger - Yanıt
I got one on ebay for about $15.
LoriP408 -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 71
Her zaman: 9,476
