Giriş
Use this guide to properly replace your speakers.
Neye ihtiyacın var
Use the plastic opening tool to undo the ten plastic clips around the back panel of the Kindle.
Using a Phillips #00 screwdriver, remove the six 4 mm screws to access the front plate.
Use the pointy end of your Spudger to separate the Speaker's connector from the motherboard on both sides.
Neredeyse bitti!
Sonuç
