Ana içeriğe geç
Fix Your Stuff
Right to Repair
Parts & Tools
Giriş
The battery, like most batteries, gives juice to the device. This guide will show you how to carefully remove it for troubleshooting purposes.
  1. Insert a plastic opening tool between the plastic panel shown on the device. Use the tool to pry the plastic away from the device.
    • Insert a plastic opening tool between the plastic panel shown on the device.
    • Use the tool to pry the plastic away from the device.
    • There will be adhesive holding this piece of plastic to the device. You may have to pull pretty hard to get it separated.
  2. Use an aluminum driver attached with a Phillips head size #00 to remove the four 3mm screws shown in the picture.  For reassembly, note that the top two and bottom two screws are different sizes.
    • Use an aluminum driver attached with a Phillips head size #00 to remove the four 3mm screws shown in the picture. For reassembly, note that the top two and bottom two screws are different sizes.
  3. Once the screws are removed, the back panel can slide off the device. Once the screws are removed, the back panel can slide off the device. Once the screws are removed, the back panel can slide off the device.
    • Once the screws are removed, the back panel can slide off the device.
    Why is step 4 needed? The magnetic component doesn’t appear to be in the way of the battery replacement. Is the magnetic component just sitting on the posts (without screws attaching)? Will any magnet work to remove it? Is there any electrical connection to this component?
    John - Yanıt
    There is no electrical connection, it is just sitting there. It should be removed so that it doesn’t fall out during the rest of the repair.
    Merlin04 - Yanıt
  4. Remove the magnetic component with the magnetic head of the aluminum driver. Remove the magnetic component with the magnetic head of the aluminum driver.
    • Remove the magnetic component with the magnetic head of the aluminum driver.
  5. Use a plastic card to pry the battery away from the device. Gently un-clip the battery plug from the device and remove the battery.
    • Use a plastic card to pry the battery away from the device.
    • Gently un-clip the battery plug from the device and remove the battery.
    The battery in mine was VERY firmly stuck with adhesive. I had to use a lot of force to remove it, and the battery bent significantly.
    Patrick Cohen (ig88b) - Yanıt
    where did you buy a battery?
    thanks
    baggins - Yanıt
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
Sean Yap
985 İtibar
6 adet Kılavuz yazıldı
Takım
Cal Poly, Team 19-12, Maness Winter 2015 Cal Poly, Team 19-12, Maness Winter 2015 üyesi
CPSU-MANESS-W15S19G12
5 Üyeler
8 Yorum
Where can I buy a replacement buttery for my kindle voyage?
hegi88 - Yanıt
Where to find a replacement battery for kindle voyage 3G please if any one knows
Himadri Endow - Yanıt
Bump. Cannot seem to procure a new battery for the Kindle Voyage. Nice to know how to replace the old one; just need something to replace it WITH! Thanks for any hints on finding one. Battery model number is: MC-305070, 3.8V 1320mAh/5.01Wh, P/N 58-000056
larryg - Yanıt
Any advance on where one can find a replacement battery for the Kindle Journal?
Charles WRIGHT - Yanıt
Still looking for a source for this battery.
Neil Hall - Yanıt
For those looking for the battery, I’ve found them on both amazon and eBay by searching “305070 battery”
Amy Galvan - Yanıt
what does the battery symbol with an “!” in it mean?
book Lover - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 37
Son 30 gün: 187
Her zaman: 11,431
