Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Insert a plastic opening tool between the plastic panel shown on the device.
Use the tool to pry the plastic away from the device.
Use an aluminum driver attached with a Phillips head size #00 to remove the four 3mm screws shown in the picture. For reassembly, note that the top two and bottom two screws are different sizes.
Once the screws are removed, the back panel can slide off the device.
Remove the magnetic component with the magnetic head of the aluminum driver.
Bu adımda kullanılan alet:Plastic Cards$2.99-
Use a plastic card to pry the battery away from the device.
Gently un-clip the battery plug from the device and remove the battery.
29 farklı kişi bu kılavuzu tamamladı.
15 Yorum
Where to find a replacement battery for kindle voyage 3G please if any one knows
Any advance on where one can find a replacement battery for the Kindle Journal?
