Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
If you are unable to connect to the internet with your Voyage there is likely a problem with your WiFi antenna. This guide is here to help you locate and remove it.
  1. Insert a plastic opening tool between the plastic panel shown on the device. Use the tool to pry the plastic away from the device.
    • Insert a plastic opening tool between the plastic panel shown on the device.
    • Use the tool to pry the plastic away from the device.
    • There will be adhesive holding this piece of plastic to the device. You may have to pull pretty hard to get it separated.
  2. Use an aluminum driver attached with a Phillips head size #00 to remove the four 3mm screws shown in the picture.  For reassembly, note that the top two and bottom two screws are different sizes.
    • Use an aluminum driver attached with a Phillips head size #00 to remove the four 3mm screws shown in the picture. For reassembly, note that the top two and bottom two screws are different sizes.
  3. Once the screws are removed, the back panel can slide off the device. Once the screws are removed, the back panel can slide off the device. Once the screws are removed, the back panel can slide off the device.
    • Once the screws are removed, the back panel can slide off the device.
  4. Remove the magnetic component with the magnetic head of the aluminum driver. Remove the magnetic component with the magnetic head of the aluminum driver.
    • Remove the magnetic component with the magnetic head of the aluminum driver.
  5. Use an aluminum driver with Phillips head #00 to remove the four 3 mm screws shown in the picture. Use the same driver to remove the two 2.5 mm screws.
    • Use an aluminum driver with Phillips head #00 to remove the four 3 mm screws shown in the picture.
    • Use the same driver to remove the two 2.5 mm screws.
  6. Using the tweezers, undo the attached clip. Remove the three 3 mm screws holding down the rest of the antenna with an aluminum driver and the Phillips #00 head. You should now be able to simply take the WiFi bar off of the device.
    • Using the tweezers, undo the attached clip.
    • Remove the three 3 mm screws holding down the rest of the antenna with an aluminum driver and the Phillips #00 head.
    • You should now be able to simply take the WiFi bar off of the device.
Sonuç
Sean Yap
1.058 İtibar
6 adet Kılavuz yazıldı
Takım
Cal Poly, Team 19-12, Maness Winter 2015 Cal Poly, Team 19-12, Maness Winter 2015 üyesi
CPSU-MANESS-W15S19G12
5 Üyeler
Bir Yorum
Re Kindle Voyage Wifi Antenna Replacement guide: I cannot find the WiFi antenna bar on your website to purchase a replacement. Do you sell it?
carol cooper - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 19
Her zaman: 1,519
