Giriş
If your Kingston HyperX Cloud II headphone bracket becomes broken due to it having the plastic piece being stepped on, fully extended, or stuck in position, use this guide to repair or replace your bracket.
Neye ihtiyacın var
Use a Phillips #0 screwdriver to remove the two 11 mm screws from the bracket support.
4 farklı kişi bu kılavuzu tamamladı.
