Ana içeriğe geç
Kingston HyperX Cloud II Speaker Wire Repair
Neye ihtiyacın var
  1. Kingston HyperX Cloud II Speaker Wire Repair, Kingston HyperX Cloud II Speaker Wire Repair: adım 1, 1 resimden 1.
    • Pulling along the edges, take off the ear padding.
  2. Kingston HyperX Cloud II Speaker Wire Repair: adım 2, 2 resimden 1. Kingston HyperX Cloud II Speaker Wire Repair: adım 2, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove the two 11 mm screws from the bracket support.
  3. Kingston HyperX Cloud II Speaker Wire Repair: adım 3, 3 resimden 1. Kingston HyperX Cloud II Speaker Wire Repair: adım 3, 3 resimden 2. Kingston HyperX Cloud II Speaker Wire Repair: adım 3, 3 resimden 3.
    • Remove the inside bracket support, and then remove the outside bracket support.
    • Expand and remove the microphone speaker from the frame.
  4. Kingston HyperX Cloud II Speaker Wire Repair: adım 4, 3 resimden 1. Kingston HyperX Cloud II Speaker Wire Repair: adım 4, 3 resimden 2. Kingston HyperX Cloud II Speaker Wire Repair: adım 4, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove the two 7.90 mm screws from the red support attached to the microphone speaker.
  5. Kingston HyperX Cloud II Speaker Wire Repair: adım 5, 3 resimden 1. Kingston HyperX Cloud II Speaker Wire Repair: adım 5, 3 resimden 2. Kingston HyperX Cloud II Speaker Wire Repair: adım 5, 3 resimden 3.
    • Separate the red frame support from the microphone speaker by putting it to the side.
  6. Kingston HyperX Cloud II Speaker Wire Repair: adım 6, 2 resimden 1. Kingston HyperX Cloud II Speaker Wire Repair: adım 6, 2 resimden 2.
    • Remove the four 11 mm screws on the speaker frame with a Phillips #2 screwdriver.
  7. Kingston HyperX Cloud II Speaker Wire Repair: adım 7, 3 resimden 1. Kingston HyperX Cloud II Speaker Wire Repair: adım 7, 3 resimden 2. Kingston HyperX Cloud II Speaker Wire Repair: adım 7, 3 resimden 3.
    • Remove the headphone speaker frame.
    • Solder the detached blue wire onto the driver.
    • Be cautious not to solder the wrong wire.
  8. Kingston HyperX Cloud II Speaker Wire Repair: adım 8, 1 resimden 1.
    • Solder the green wire onto the driver.
Sonuç
Daniel Olaoluwa Ajagbonna
337 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-4, Harley Spring 2023 IUPUI, Team 1-4, Harley Spring 2023 üyesi
IUPUI-HARLEY-S23S1G4
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 28
Son 30 gün: 122
Her zaman: 2,531
