Ana içeriğe geç
Kingston HyperX CloudX Speaker Sponge Replacement
Neye ihtiyacın var
  1. Kingston HyperX CloudX Speaker Sponge Replacement, Speaker Sponge: adım 1, 1 resimden 1.
    • Remove the ear cushion from the earphone.
  2. Kingston HyperX CloudX Speaker Sponge Replacement: adım 2, 2 resimden 1. Kingston HyperX CloudX Speaker Sponge Replacement: adım 2, 2 resimden 2.
    • Remove four 11.2 mm screws from the earpiece using a Phillips #00 screwdriver.
  3. Kingston HyperX CloudX Speaker Sponge Replacement: adım 3, 2 resimden 1. Kingston HyperX CloudX Speaker Sponge Replacement: adım 3, 2 resimden 2.
    • Use a spudger to pry the top plate away from the motherboard.
    • There will be a groove in between the two plates to insert the spudger.
  4. Kingston HyperX CloudX Speaker Sponge Replacement: adım 4, 1 resimden 1.
    • Use the metal spudger tool to scrape off the old foam pad and any remaining glue.
    • The plate does not have to be completely clean after removal, just clean enough to securely attach the new sponge.
  5. Kingston HyperX CloudX Speaker Sponge Replacement: adım 5, 1 resimden 1.
    • Line the edge of the headphone plate where the original pad was with superglue.
    • Press the new sponge into the glue and allow it to dry fully.
    • The new sponge may need to be cut to size in order to fit on the headphone plate.
    • Make sure the glue is completely dry before reassembling your device. Failure to do this may result in damage of your device.
Sonuç
Kosie
121 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 93
