Ana içeriğe geç
Kirby G5 Vacuum Belt Replacement
Neye ihtiyacın var
  1. Kirby G5 Vacuum Belt Replacement, Vacuum Belt: adım 1, 1 resimden 1.
    • Place the vacuum at an angle most comfortable and easy to access with the bottom facing upwards.
  2. Kirby G5 Vacuum Belt Replacement: adım 2, 2 resimden 1. Kirby G5 Vacuum Belt Replacement: adım 2, 2 resimden 2.
    • Remove the three screws holding the base plate to the body of the vacuum using a flat head screwdriver.
    • Place the plate to the side.
  3. Kirby G5 Vacuum Belt Replacement: adım 3, 1 resimden 1.
    • Simply slide the roller out of the vacuum.
    • The belt is attached to the roller on either side.
  4. Kirby G5 Vacuum Belt Replacement: adım 4, 2 resimden 1. Kirby G5 Vacuum Belt Replacement: adım 4, 2 resimden 2.
    • Slide the vacuum belt out from beneath the wheel holding it in place.
  5. Kirby G5 Vacuum Belt Replacement: adım 5, 1 resimden 1.
    • Insert your new belt and pop the roller back into place.
  6. Kirby G5 Vacuum Belt Replacement: adım 6, 2 resimden 1. Kirby G5 Vacuum Belt Replacement: adım 6, 2 resimden 2.
    • Secure the plate once again until it clicks into the made grooves.
    • Secure the three screws until tightened.
Sonuç
Make sure to test the vacuum and securely tighten all screws. With that, you’re good to go!
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 47
Her zaman: 1,478
