Ana içeriğe geç
Kitchen Drawer Rear Mounts Replacement
Neye ihtiyacın var
  1. Kitchen Drawer Rear Mounts Replacement, Rear drawer mounts: adım 1, 2 resimden 1. Kitchen Drawer Rear Mounts Replacement, Rear drawer mounts: adım 1, 2 resimden 2.
    • Remove all utensils from the drawer and remove the drawer from the slot.
  2. Kitchen Drawer Rear Mounts Replacement: adım 2, 2 resimden 1. Kitchen Drawer Rear Mounts Replacement: adım 2, 2 resimden 2.
    • Start removing the mounts and tracks by unscrewing them with your drill or screwdriver.
    • Your replacement tracks or mounts will come with new screws.
  3. Kitchen Drawer Rear Mounts Replacement: adım 3, 1 resimden 1.
    • Once you have all your new material, insert the mounts onto your track.
  4. Kitchen Drawer Rear Mounts Replacement: adım 4, 1 resimden 1.
    • Take the track with the new mount attached and screw it into the existing hole using the new screws that came in the packaging.
  5. Kitchen Drawer Rear Mounts Replacement: adım 5, 2 resimden 1. Kitchen Drawer Rear Mounts Replacement: adım 5, 2 resimden 2.
    • After the track has one screw drilled, use a level to make sure your track is straight.
    • Depending on your new mounts, you may or may not need to drill new holes for the screws. If you do need to drill new holes mark the holes on the mount with a pencil or marker.
  6. Kitchen Drawer Rear Mounts Replacement: adım 6, 1 resimden 1.
    • Drill the screws in either the existing holes or marked spots to hold the mount in place.
  7. Kitchen Drawer Rear Mounts Replacement: adım 7, 1 resimden 1.
    • Repeat these steps on the other side if needed.
  8. Kitchen Drawer Rear Mounts Replacement: adım 8, 1 resimden 1.
    • Place your drawer back into its place and you are now done with your repair!
Sonuç
Now that your repair is done make sure your drawer is sliding smoothly if not you will need to remove it and clean the tracks. Another thing to look for is if the tracks are perfectly aligned if not you can go back in and fix them by following the same steps again.
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 24
Son 30 gün: 85
Her zaman: 3,888
