Ana içeriğe geç
Kitchen Shut-Off Valve Replacement
Neye ihtiyacın var
  1. Kitchen Shut-Off Valve Replacement, Kitchen Shut-Off Valve: adım 1, 1 resimden 1.
    • Ensure the main water supply is shut off to prevent any water from flowing while you start this repair.
    • The water supply valve can be located anywhere from your basement, water heater, furnace, or garage.
  2. Kitchen Shut-Off Valve Replacement: adım 2, 1 resimden 1.
    • Open the cabinet under the kitchen sink and ensure the workplace is clean and free from clutter.
  3. Kitchen Shut-Off Valve Replacement: adım 3, 1 resimden 1.
    • Use the screwdriver to unscrew the valve from the pipe.
  4. Kitchen Shut-Off Valve Replacement: adım 4, 1 resimden 1.
    • Prepare the bucket under the valve and when ready, use an adjustable wrench to loosen the nut that connects the shut-off valve to the water supply pipe, make sure the wrench tightly grasps the nut and start turning counter-clockwise gently.
    • Be careful when repairing to not use excessive force, as you could damage the pipe or the valve.
  5. Kitchen Shut-Off Valve Replacement: adım 5, 1 resimden 1.
    • Clean the valve using a cleaning rag, making sure it is all ready to be replaced.
  6. Kitchen Shut-Off Valve Replacement: adım 6, 1 resimden 1.
    • Screw the new shut-off valve onto the pipe with your new stem kit.
  7. Kitchen Shut-Off Valve Replacement: adım 7, 1 resimden 1.
    • Screw the valve by tightening it with your adjustable wrench.
    • Reconnect the water supply line to the valve, making sure it’s tightly secured in place.
    • Be careful not to overtighten, as this can damage the valve/pipe.
  8. Kitchen Shut-Off Valve Replacement: adım 8, 1 resimden 1.
    • Now tighten the nut from the top as shown, to tightly secure the shut-off valve again.
    • Do NOT overtighten.
  9. Kitchen Shut-Off Valve Replacement: adım 9, 1 resimden 1.
    • Use the screwdriver to screw the valve back on. To do this, first insert the valve and then put the screw back into the socket. Then start tightening, but do not overtighten it, as it can damage the valve and/or the pipe.
    • Once completed, you have officially replaced/cleaned the kitchen shut-off valve. Good work!
Bitiş Çizgisi
Nickcoy Jadhav
169 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 38
Her zaman: 611
