Ana içeriğe geç
Kitchen Sink Basket Strainer Replacement
Neye ihtiyacın var
  1. Kitchen Sink Basket Strainer Replacement, Basket Strainer: adım 1, 1 resimden 1.
    • Shut off the hot and cold water supply valves under the sink.
    • Turn the handles clockwise and make sure the water is off before moving on.
  2. Kitchen Sink Basket Strainer Replacement: adım 2, 2 resimden 1. Kitchen Sink Basket Strainer Replacement: adım 2, 2 resimden 2.
    • Remove the stopper from the basket strainer by lifting it out.
  3. Kitchen Sink Basket Strainer Replacement: adım 3, 2 resimden 1. Kitchen Sink Basket Strainer Replacement: adım 3, 2 resimden 2.
    • Loosen the trap adapter nut under the sink.
    • Use the pliers and turn counterclockwise to loosen the nut.
  4. Kitchen Sink Basket Strainer Replacement: adım 4, 2 resimden 1. Kitchen Sink Basket Strainer Replacement: adım 4, 2 resimden 2.
    • Loosen the tailpiece nut under the basket strainer.
  5. Kitchen Sink Basket Strainer Replacement: adım 5, 2 resimden 1. Kitchen Sink Basket Strainer Replacement: adım 5, 2 resimden 2.
    • Loosen the nut of the basket strainer.
  6. Kitchen Sink Basket Strainer Replacement: adım 6, 1 resimden 1.
    • Remove the basket strainer from the sink by lifting it out.
  7. Kitchen Sink Basket Strainer Replacement: adım 7, 1 resimden 1.
    • Remove the tailpiece from the trap adaptor by lifting it out.
    • Keep the trap adapter nut and the nylon slip washer aside.
    • The trap adapter nut and nylon slip washer are shown in the image. The nylon slip is within the trap adaptor.
  8. Kitchen Sink Basket Strainer Replacement: adım 8, 2 resimden 1. Kitchen Sink Basket Strainer Replacement: adım 8, 2 resimden 2.
    • Clean the sink opening and install a new basket strainer and the tailpiece.
    • Image 2 shows all the pieces that should be included in your new kit.
  9. Kitchen Sink Basket Strainer Replacement: adım 9, 1 resimden 1.
    • Slide the old trap adaptor nut and nylon slip washer over the tailpiece.
  10. Kitchen Sink Basket Strainer Replacement: adım 10, 1 resimden 1.
    • Install the tailpiece into the trap adaptor with the tailpiece washer inserted on top.
  11. Kitchen Sink Basket Strainer Replacement: adım 11, 1 resimden 1.
    • Place the basket strainer on top of the tailpiece.
  12. Kitchen Sink Basket Strainer Replacement: adım 12, 2 resimden 1. Kitchen Sink Basket Strainer Replacement: adım 12, 2 resimden 2.
    • Align the upper strainer to the basket under the sink and tighten it with the nut supplied.
    • Use the pliers and turn clockwise to tighten the nut.
  13. Kitchen Sink Basket Strainer Replacement: adım 13, 1 resimden 1.
    • Tighten the tailpiece nut to the basket.
  14. Kitchen Sink Basket Strainer Replacement: adım 14, 1 resimden 1.
    • Tighten the trap adaptor nut.
  15. Kitchen Sink Basket Strainer Replacement: adım 15, 1 resimden 1.
    • Insert the strainer and turn the water back on to test for any leaks.
Bitiş Çizgisi
Daniel Mella
241 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 34
Son 30 gün: 93
Her zaman: 3,257
