Ana içeriğe geç
KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Powertrain/Motor Replacement
Neye ihtiyacın var
    • Before starting ANY repair/disassembly of the mixer, make sure it is fully unplugged from the electrical outlet.
    • While this model is not recommended for commercial use, if the mixer is being used in a commercial environment, a LOTO tag can be affixed via the hole on one of the prongs on the mains plug to prevent accidental activation.
    • The speed/motor control assembly contains capacitors which can retain their charge for an indefinite amount of time. These capacitors can present a significant and potentially fatal shock hazard.
  1. KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Powertrain/Motor Replacement, Remove the Planetary Assembly: adım 2, 3 resimden 1. KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Powertrain/Motor Replacement, Remove the Planetary Assembly: adım 2, 3 resimden 2. KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Powertrain/Motor Replacement, Remove the Planetary Assembly: adım 2, 3 resimden 3.
    • Place a couple dish towels or other soft materials on the base to protect it from any potential impact.
    • Disconnect the planetary from the motor drive shaft by removing the retaining pin (circled in yellow). You can do this with a hammer and either a pin punch or a Torx T15 screwdriver. Simply hammer the punch/screwdriver on the pin until it comes out the other side.
    • If the planetary assembly doesn't fall out, you might have to give it a firm pull straight down to remove it.
  2. KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Powertrain/Motor Replacement, Remove the trim band: adım 3, 1 resimden 1.
    • Using a #2 Philips Screwdriver, remove the screw which holds on the trim band.
    • Remove the trim band.
  3. KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Powertrain/Motor Replacement, Remove the mixer cover: adım 4, 3 resimden 1. KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Powertrain/Motor Replacement, Remove the mixer cover: adım 4, 3 resimden 2. KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Powertrain/Motor Replacement, Remove the mixer cover: adım 4, 3 resimden 3.
    • Remove the four screws (circled in yellow, two on each side) using a #2 Philips Screwdriver
    • Remove the cover by lifting it straight up.
  4. KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Powertrain/Motor Replacement, Remove the main planetary gear: adım 5, 3 resimden 1. KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Powertrain/Motor Replacement, Remove the main planetary gear: adım 5, 3 resimden 2. KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Powertrain/Motor Replacement, Remove the main planetary gear: adım 5, 3 resimden 3.
    • Using the T25 Torx Screwdriver, remove the four torx screws by the powertrain (circled in yellow, two on each side)
    • When removing the last screw, make sure to place your hand under the planetary gear as it is heavy and will fall out immediately.
  5. KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Powertrain/Motor Replacement, Disconnect the motor: adım 6, 3 resimden 1. KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Powertrain/Motor Replacement, Disconnect the motor: adım 6, 3 resimden 2. KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Powertrain/Motor Replacement, Disconnect the motor: adım 6, 3 resimden 3.
    • Remove the hall effect sensor from its mount by pressing down on the tab (circled in yellow in the first picture) and sliding it out.
    • Disconnect the power cable by holding down the clip on the right side of the plug (circled in blue in the second picture) and pulling the plug straight up.
  6. KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Powertrain/Motor Replacement, Removing the powertrain/motor: adım 7, 2 resimden 1. KitchenAid 5.5/6.0/7.0-quart Bowl-Lift Stand Mixers (Models: KSM55/KSM60/KSM70) - Powertrain/Motor Replacement, Removing the powertrain/motor: adım 7, 2 resimden 2.
    • Using a #2 Philips screwdriver, remove the four screws (indicated in yellow, two on each side) attaching the powertrain to the mixer body.
    • When removing the last screw, support the motor as it is no longer connected to the mixer body and could damage the Speed/Motor Control Assembly circuit board underneath.
    • Remove the powertrain.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
PedroDaGr8
3.059 İtibar
15 adet Kılavuz yazıldı
2 Yorum
ksm55sxxxcu is the new version i could not replace the motor it has an inner conjuction with the tip.
I could not seperate the motor from the tip. Could you help?
leventercan@gmail.com
levent ercan - Yanıt
Apologies if I misunderstand your question, it is not very clear what you mean by 'inner conjunction' and 'tip'.
The motor is not designed to be taken apart beyond the instructions in this guide. As I state in the beginning of this guide: the motor, the gearbox, and the transfer gears are a single unit.
PedroDaGr8 -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 16
Son 30 gün: 84
Her zaman: 2,745
