Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
If your mixer won't spin or is noisy, follow our guide on how to replace the worm gear.
  1. Using a spudger, gently pry off the aluminum drip ring. Using a spudger, gently pry off the aluminum drip ring.
    • Using a spudger, gently pry off the aluminum drip ring.
    Unplug the Mixer.
    Mike Reckner - Yanıt
    Good call! Nobody likes digital trauma
    David Brand - Yanıt
  2. Using a 4 mm pin punch and hammer, hammer the pin until it is dislodged from the planetary gear cover.
    • Using a 4 mm pin punch and hammer, hammer the pin until it is dislodged from the planetary gear cover.
    This should be a 5/32 inch or 4mm punch.
    Patrick Hailstone - Yanıt
    For mine it is so stiff and I cant put out the pin with hammer
    Omid - Yanıt
    The pin is not moving: is there any other way of removing it or completing the job without removing it?
    ollver - Yanıt
    My pin is stuck too, are there any other ways?
    Nabil Baker - Yanıt
    Can the pin be hammered from either side. It won’t budge
    Sally Stier - Yanıt
    Just keep at it, mine didn’t budge for a while
    Robert Chauharjasingh - Yanıt
    No way. I ‘ve tried for an hour and it didn’t move at all. But I ‘ve found a solution. I drilled it out. First with 2mm then with a 3mm drill. Then I could easily remove it. The replace part is a 4mm x ~22.5mm grooved pin (half-length-center-grooved; ISO 8743).
    Zwiebeljack - Yanıt
    Mine was also stubborn. I laid the machine on the side and sprayed WD-40 in the pin several times. Waited 30 min and then it came out easy.
    Petter Hellevik - Yanıt
  3. Using a spudger, pry the planetary gear cover from the mixer shaft. Using a spudger, pry the planetary gear cover from the mixer shaft.
    • Using a spudger, pry the planetary gear cover from the mixer shaft.
  4. Using a flathead screwdriver, remove the five 28 mm front motor housing screws.
    • Using a flathead screwdriver, remove the five 28 mm front motor housing screws.
    • Using the same flathead screwdriver, remove the two 28 mm locking screws.
    • One of the locking screws contains a safety locking mechanism. Do not interchange these screws with the front motor housing screws.
    Hier Werder mittlerweile Vierkantschrauben in 3/32 Zoll verbaut. Wie bekomme ich die auf?
    Chris - Yanıt
    Classic Plus uses a square-drive screw. You’ll need #1 size.
    Robert Kyle - Yanıt
  5. Turn your device around. Using the same flathead screwdriver, remove the two 28 mm rear locking screws.
    • Turn your device around. Using the same flathead screwdriver, remove the two 28 mm rear locking screws.
    • One of the rear motor housing screws contains a safety locking mechanism. Do not interchange these screws with the front motor housing screws.
  6. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Hemen Alışveriş Yapın
  7. Using a Phillips #2 screwdriver, remove the 10 mm screw from top of back cover. The rear cover is now completely free from the mixer.
    • Using a Phillips #2 screwdriver, remove the 10 mm screw from top of back cover.
    • The rear cover is now completely free from the mixer.
    When I removed this, 2 nuts were in there lose. I cannot tell where they came from.
    Nila Tae - Yanıt
  8. Carefully pull the power cord from the notch in back of the mixer. The motor housing cover is now completely free from the base of the mixer.
    • Carefully pull the power cord from the notch in back of the mixer.
    • The motor housing cover is now completely free from the base of the mixer.
    For the KSM90BU model, take a set of needlenose pliers and carefully rotate the plastic clip 90 degrees, then pull the cord out of the notch.
    Charles Lester - Yanıt
  9. Lift the motor housing cover from the mixer base.
    • Lift the motor housing cover from the mixer base.
    • Be sure to place the cover upside-down to prevent grease from leaking out.
    Und wie komme ich nun an den Motor zur Reinigung des Unterbrechers?
    Arbeitsgruppe Dialog - Yanıt
  10. Using a butter knife or putty knife, remove the grease from the gears. Place the grease in motor housing cover.
    • Using a butter knife or putty knife, remove the grease from the gears.
    • Place the grease in motor housing cover.
    Gib das Fett AUF KEINEN FALL in das Motorgehäuse zurück. Die KA ist werkseitig mit mit einem Fett befüllt, welches schnell altert und sich in teilweise verflüssigt. Auch bei dieser Maschine ist zu sehen, dass es bereits an der Dichtung vorbei austritt. Wer sich schon die Mühe dieser Reparatur macht, sollte die Gelegenheit nutzen, auch das Fett zu tauschen. Es sollte ein verseiftes Fett der NLGI Klasse 2 sein. Sehr vorsichtige Menschen können ein lebensmittelechtes verwenden.
    Marc Malkwitz - Yanıt
  11. Using a Phillips #2 screwdriver, remove the three 20 mm screws from the worm gear tower.
    • Using a Phillips #2 screwdriver, remove the three 20 mm screws from the worm gear tower.
    • The worm gear tower assembly is now free from the mixer base.
  12. Using a pin punch and a hammer, remove the roll pin. Using a pin punch and a hammer, remove the roll pin.
    • Using a pin punch and a hammer, remove the roll pin.
  13. Slide the tower gear out to access the worm gear.
    • Slide the tower gear out to access the worm gear.
  14. Remove the worm gear from the tower.
    • Remove the worm gear from the tower.
    Helpful pictures
    Dawn - Yanıt
    This also works for the KSM90BU model
    Excellent instructions!! Pictures were very helpful. A total novice and I fixed my mixer in 35 minutes. Thanks!!
    Jo Hasselman - Yanıt
Sonuç
33 farklı kişi bu kılavuzu tamamladı.
Chris Grant
978 İtibar
1 Kılavuz yazıldı
Takım
Cal Poly, Team 14-28, Maness Fall 2014 Cal Poly, Team 14-28, Maness Fall 2014 üyesi
CPSU-MANESS-F14S14G28
4 Üyeler
12 adet Kılavuz yazıldı
20 Yorum
Some corrections:
Step 1 -- Suggest (as the Service Manual does) using a flat-blade screwdriver and tap it with a light hammer to drive the drip ring off.
Step 2 -- the correct size pin punch is 5/32"
Step 3 -- Using two flat-blade screwdrivers, one on each side, pry off the planetary.
A plastic spudger is likely to break. Two points of leverage opposits each other distributes the load and prevents to the planetary and its shaft.
Step 11 -- The proper punch size is 3/32"
Steps 12 & 13 -- There is a washer on each side of the worm gear. Retain these and place one on each side off the grar when reassembling.
A link to the Service Manual:
http://www.kitchenaidparts.eu/documents/...
Finkerbell - Yanıt
Cheers Finkerbell,
Very helpful info, as was the main part of the guide.
Not sure what model number I was working on, but when I l lifted off the motor housing, there was still wires connected to the base.
Just be careful at this stage in case you have the same...
markguerin - Yanıt
my model K5SS WH is the same as yours until step 5. It doesnt have the two bolts as shown in the picture for step 5 so i wasnt able to complete the repair. any suggestions.
sailsetter - Yanıt
Wow! Lovely guide to easy maintenance, no plenty stories
Dennis - Yanıt
This is the BEST! Thank you.
Advanamics - Yanıt
is there any chance of using stronger gears as replacement parts?
rslaughter65 - Yanıt
You shouldn’t want to, this plastic gear serves as a kind of mechanical fuse to protect the motor from failure. If the system is overloaded (or worse freezes to a stop) the gear will shear off protecting the motor from overload. This part was not designed as “planned obsolescence” as the rumor states but was actually a safety feature as an easily accessible and cheap plastic gear is a much better replacement than a motor.
PedroDaGr8 -
I can't punch the pin out. Any ideas?
Denise Olson - Yanıt
Denise,
I had the same problem.  Knocking the pin out looks so easy in the videos, but was not so in my case.  I put the mixer on the floor and butted the side up against a wall, with a towel for padding between the mixer and the baseboard.  Another option would be to lay the mixer on its side on a board and a towel for padding.  The idea is to keep the mixer from moving when driving out the pin.  You may also try applying some WD-40 to each side of the pin.  I used a large nailset, which slipped less than the punch, and just kept tapping on the pin.   I used more force each time until the pin started to move, and then maintained that force until the pin was out.  Driving the pin back in was equally as difficult.  I added some grease to the pin when reinstalling, but I am not certain that it helped any.  Good luck!
Craig -
FYI - The motor would hum on my mixer, but the mixer would not spin. I followed this guide under the impression that the gear was trashed, but upon disassembly found that the gear was in good shape.  It turned out that gear at the front of the blender that powers attachments was stuck.  With the mixer still disassembled,  I removed the front cover (the chrome piece at the front end), and used a punch to drive the gear back into the blender so it could be removed.  Simply cleaning gunk off of the gear shaft and the bearing with steel wool, applying some light grease, and reassembling, fixed this mixer.
Craig -
RE: Introduction : This may be terribly obvious/nit picky, but you might need the replacement part before doing this. Saying you need no parts seems pretty silly. Other than that these directions are very useful/good.
maineuropa - Yanıt
I had expected to see a toothless plastic gear in the grease, but alas, what I did find was the small metal tower gear was missing more than half of its teeth! The plastic gear appears intact. I was able to find 3 of the teeth in the housing, but I fear the other 3 or 4 are lost in the grease blob, so I will have to purge the whole mess and start over. The larger main gear might also be damaged; I haven’t gotten that cleaned up yet, but all its teeth are present. Beware old crystalized brown sugar lumps!
Tim Fowlks - Yanıt
The disassembly instructions are quite good, by the way. Thanks a bunch!
Tim Fowlks - Yanıt
Buy a better mixer next time that doesn’t use a cheap gear, don’t catch KitchenAid’s
Terry Vanderpuke - Yanıt
Any recommendations for the type of gear lube?
nshourds - Yanıt
Just found it: KitchenAid recommends using any food grade lubricant to grease the gearing. Such as this one: https://www.amazon.com/Grade-Grease-Kitc...
nshourds -
Works for 5KPM5EWH too! Thanks!
Felix Büchler - Yanıt
For those having trouble with the pin here’s a workaround:
Skip steps 2 & 3. In step 4 you should be able to loosen the screws quite a bit before they hit the top of the planetary gear cover. Proceed through step 7 and now you should be able to wiggle/pry the top up until the front screws reach their limit, at which point you can continue to remove them completely.
Dan Jabbour - Yanıt
hello I got to the point of removing the roll pin in the worm gear and can not get the roll pin to punch out any suggestions…on specific tool I can use my punch did not work and seems to be flattening the rol pin
Lisa A Hypnar - Yanıt
Bitte nicht das alte Fett wieder verwenden! Die Kitchen Aid ist werkseitig mit mit einem Fett befüllt, welches schnell altert und sich teilweise verflüssigt. Auch bei dieser Maschine ist zu sehen, dass es bereits an der Dichtung vorbei austritt. Wer sich die Mühe dieser Reparatur macht, sollte die Gelegenheit nutzen, auch das Fett zu tauschen! Es kann jedes verseifte Schmierfett der NLGI Klasse 2 verwendet werden. Sehr vorsichtige Menschen können lebensmittelechtes Schmierfett verwenden.
Please do not reuse the old grease! The KitchenAir is factory-filled with a grease that ages quickly and tends to liquefy. The photos here show, how grease leaks past the seal. Once you do the effort of this repair, take the opportunity to change the grease! Any NLGI class 2 saponified grease will do. Very careful people can use food grade grease.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 94
Son 7 gün: 462
Son 30 gün: 2,647
Her zaman: 44,217
