Ana içeriğe geç
KitchenAid KHM512ER Beater Rings Replacement
Neye ihtiyacın var
  1. KitchenAid KHM512ER Beater Rings Replacement, Beater Rings: adım 1, 2 resimden 1. KitchenAid KHM512ER Beater Rings Replacement, Beater Rings: adım 1, 2 resimden 2.
    • Insert the back of a plastic opening tool into one of the beater holes
    • Apply force to pull the circular plastic part off.
    • If necessary, use the other side of the plastic opening tool to pry the circular plastic part off.
  2. KitchenAid KHM512ER Beater Rings Replacement: adım 2, 2 resimden 1. KitchenAid KHM512ER Beater Rings Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #2 screwdriver to remove the two 20mm screws holding the bottom plastic piece in place.
    • Remove the bottom plastic piece using a plastic opening tool.
  3. KitchenAid KHM512ER Beater Rings Replacement: adım 3, 2 resimden 1. KitchenAid KHM512ER Beater Rings Replacement: adım 3, 2 resimden 2.
    • Using a Phillips 2 screwdriver, remove the three 20.0mm screws holding the motor assembly in place.
    • Use your hands to remove the motor assembly.
  4. KitchenAid KHM512ER Beater Rings Replacement: adım 4, 2 resimden 1. KitchenAid KHM512ER Beater Rings Replacement: adım 4, 2 resimden 2.
    • Firmly grip the motor in your hand. Using pliers, pull the connectors off the motors.
    • Some force may be required. Be careful not to cut yourself on any electrical components.
  5. KitchenAid KHM512ER Beater Rings Replacement: adım 5, 2 resimden 1. KitchenAid KHM512ER Beater Rings Replacement: adım 5, 2 resimden 2.
    • Lie the motor down flat on a table.
    • Using a pair of tweezers, remove the ring from the plastic knob.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Brad Daniels
621 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-3, Sullivan Spring 2016 USF Tampa, Team 2-3, Sullivan Spring 2016 üyesi
USFT-SULLIVAN-S16S2G3
3 Üyeler
4 adet Kılavuz yazıldı
3 Yorum
Anyone know of a site that sells replacement beater gears?
joescherzo - Yanıt
Nice set by step process but where does one get the rings?
M Stevens - Yanıt
try Sears parts.com
Yvette Tower - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 53
Her zaman: 6,628
