Ana içeriğe geç
KitchenAid KHM512ER Eject Button Spring Replacement
Neye ihtiyacın var
    1. KitchenAid KHM512ER Eject Button Spring Replacement, Eject Button Spring: adım 1, 2 resimden 1. KitchenAid KHM512ER Eject Button Spring Replacement, Eject Button Spring: adım 1, 2 resimden 2.
      • Insert the back of a plastic opening tool into one of the beater holes.
      • Apply force to pull the circular plastic part off.
      • If necessary, use the other side of the plastic opening tool to pry the circular plastic part off.
      FixBot'a Sor
      Yorum Ekle
    2. KitchenAid KHM512ER Eject Button Spring Replacement: adım 2, 3 resimden 1. KitchenAid KHM512ER Eject Button Spring Replacement: adım 2, 3 resimden 2. KitchenAid KHM512ER Eject Button Spring Replacement: adım 2, 3 resimden 3.
      • Use a plastic opening tool to remove the speed knob.
      • Use a plastic opening tool to remove the long plastic piece
      • Use a plastic opening tool to remove the speed switch.
      FixBot'a Sor
      Yorum Ekle
    3. KitchenAid KHM512ER Eject Button Spring Replacement: adım 3, 2 resimden 1. KitchenAid KHM512ER Eject Button Spring Replacement: adım 3, 2 resimden 2.
      • Use a Phillips 2 screwdriver to remove the two 20.0mm screws holding the bottom plastic piece on.
      • Your screwdriver may not be long or narrow enough to reach the screws in these holes. If that's the case, use another screwdriver.
      • Remove the bottom plastic piece using a plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    4. KitchenAid KHM512ER Eject Button Spring Replacement: adım 4, 3 resimden 1. KitchenAid KHM512ER Eject Button Spring Replacement: adım 4, 3 resimden 2. KitchenAid KHM512ER Eject Button Spring Replacement: adım 4, 3 resimden 3.
      • Using a Phillips 2 screwdriver, remove the three 20.0mm screws holding the motor assembly in place.
      • Use your hands to remove the motor assembly.
      • Use your hands to hold the eject button from one side while using the other hand to remove the circuit board.
      FixBot'a Sor
      Yorum Ekle
    5. KitchenAid KHM512ER Eject Button Spring Replacement: adım 5, 2 resimden 1. KitchenAid KHM512ER Eject Button Spring Replacement: adım 5, 2 resimden 2.
      • Remove the eject button by pulling it from the inside of the mixer.
      • Hold the eject button firmly while pulling out the spring.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Yuriy Zaynulin
191 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 2-3, Sullivan Spring 2016 USF Tampa, Team 2-3, Sullivan Spring 2016 üyesi
USFT-SULLIVAN-S16S2G3
3 Üyeler
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 39
Her zaman: 2,115
