Ana içeriğe geç
KitchenAid KHM512ER Eject Button Spring Replacement
Neye ihtiyacın var
  1. KitchenAid KHM512ER Eject Button Spring Replacement, Eject Button Spring: adım 1, 2 resimden 1. KitchenAid KHM512ER Eject Button Spring Replacement, Eject Button Spring: adım 1, 2 resimden 2.
    • Insert the back of a plastic opening tool into one of the beater holes.
    • Apply force to pull the circular plastic part off.
    • If necessary, use the other side of the plastic opening tool to pry the circular plastic part off.
  2. KitchenAid KHM512ER Eject Button Spring Replacement: adım 2, 3 resimden 1. KitchenAid KHM512ER Eject Button Spring Replacement: adım 2, 3 resimden 2. KitchenAid KHM512ER Eject Button Spring Replacement: adım 2, 3 resimden 3.
    • Use a plastic opening tool to remove the speed knob.
    • Use a plastic opening tool to remove the long plastic piece
    • Use a plastic opening tool to remove the speed switch.
  3. KitchenAid KHM512ER Eject Button Spring Replacement: adım 3, 2 resimden 1. KitchenAid KHM512ER Eject Button Spring Replacement: adım 3, 2 resimden 2.
    • Use a Phillips 2 screwdriver to remove the two 20.0mm screws holding the bottom plastic piece on.
    • Your screwdriver may not be long or narrow enough to reach the screws in these holes. If that's the case, use another screwdriver.
    • Remove the bottom plastic piece using a plastic opening tool.
  4. KitchenAid KHM512ER Eject Button Spring Replacement: adım 4, 3 resimden 1. KitchenAid KHM512ER Eject Button Spring Replacement: adım 4, 3 resimden 2. KitchenAid KHM512ER Eject Button Spring Replacement: adım 4, 3 resimden 3.
    • Using a Phillips 2 screwdriver, remove the three 20.0mm screws holding the motor assembly in place.
    • Use your hands to remove the motor assembly.
    • Use your hands to hold the eject button from one side while using the other hand to remove the circuit board.
  5. KitchenAid KHM512ER Eject Button Spring Replacement: adım 5, 2 resimden 1. KitchenAid KHM512ER Eject Button Spring Replacement: adım 5, 2 resimden 2.
    • Remove the eject button by pulling it from the inside of the mixer.
    • Hold the eject button firmly while pulling out the spring.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Yuriy Zaynulin
191 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 2-3, Sullivan Spring 2016 USF Tampa, Team 2-3, Sullivan Spring 2016 üyesi
USFT-SULLIVAN-S16S2G3
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 54
Her zaman: 1,996
