Ana içeriğe geç
KitchenAid KHM512ER Motor Replacement
Neye ihtiyacın var
  1. KitchenAid KHM512ER Motor Replacement, Motor: adım 1, 2 resimden 1. KitchenAid KHM512ER Motor Replacement, Motor: adım 1, 2 resimden 2.
    • Insert the back of a plastic opening tool into one of the beater holes
    • Apply force to pull the circular plastic part off.
    • If necessary, use the other side of the plastic opening tool to pry the circular plastic part off.
    FixBot'a Sor
    Yorum Ekle
  2. KitchenAid KHM512ER Motor Replacement: adım 2, 2 resimden 1. KitchenAid KHM512ER Motor Replacement: adım 2, 2 resimden 2.
    • Use a Phillips 2 screwdriver to remove the two 20mm screws holding the bottom plastic piece in place.
    • Remove the bottom plastic piece using a plastic opening tool.
    • Your screwdriver may not be long or narrow enough to reach the screws in these holes. If that's the case, use another screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. KitchenAid KHM512ER Motor Replacement: adım 3, 2 resimden 1. KitchenAid KHM512ER Motor Replacement: adım 3, 2 resimden 2.
    • Using a Phillips 2 screwdriver, remove the three 20mm screws holding the motor assembly in place.
    • Use your hands to remove the motor assembly and circuit board.
    FixBot'a Sor
    Yorum Ekle
  4. KitchenAid KHM512ER Motor Replacement: adım 4, 3 resimden 1. KitchenAid KHM512ER Motor Replacement: adım 4, 3 resimden 2. KitchenAid KHM512ER Motor Replacement: adım 4, 3 resimden 3.
    • Firmly grip the motor in your hand. Using pliers, pull the connectors off the motors.
    • Some force may be required. Be careful not to cut yourself on any electrical components.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
[deleted]
134 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 43
Her zaman: 5,456
