Ana içeriğe geç
KitchenAid KHM512ER Power Cord Replacement
Neye ihtiyacın var
    1. KitchenAid KHM512ER Power Cord Replacement, Power Cord: adım 1, 2 resimden 1. KitchenAid KHM512ER Power Cord Replacement, Power Cord: adım 1, 2 resimden 2.
      • Insert the back of a plastic opening tool into one of the beater holes
      • Apply force to pull the circular plastic part off.
      • If necessary, use the other side of the plastic opening tool to pry the circular plastic part off.
      FixBot'a Sor
      Yorum Ekle
    2. KitchenAid KHM512ER Power Cord Replacement: adım 2, 3 resimden 1. KitchenAid KHM512ER Power Cord Replacement: adım 2, 3 resimden 2. KitchenAid KHM512ER Power Cord Replacement: adım 2, 3 resimden 3.
      • Use a plastic opening tool to remove the speed knob.
      • Pop up the panel with a plastic opening tool.
      • Use a plastic opening tool to pry the white plastic switch assembly out.
      FixBot'a Sor
      Yorum Ekle
    3. KitchenAid KHM512ER Power Cord Replacement: adım 3, 2 resimden 1. KitchenAid KHM512ER Power Cord Replacement: adım 3, 2 resimden 2.
      • Use a Phillips 2 screwdriver to remove the two 20.0mm screws that hold the bottom plastic piece.
      • Your screwdriver may not be long or narrow enough to reach the screws in these holes. If that's the case, use another screwdriver.
      • Remove the bottom plastic piece using a plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    4. KitchenAid KHM512ER Power Cord Replacement: adım 4, 3 resimden 1. KitchenAid KHM512ER Power Cord Replacement: adım 4, 3 resimden 2. KitchenAid KHM512ER Power Cord Replacement: adım 4, 3 resimden 3.
      • Using a Phillips 2 screwdriver, remove the three 20.0mm screws holding the motor assembly in place.
      • Use your hands to remove the motor assembly and circuit board.
      FixBot'a Sor
      Yorum Ekle
    5. KitchenAid KHM512ER Power Cord Replacement: adım 5, 3 resimden 1. KitchenAid KHM512ER Power Cord Replacement: adım 5, 3 resimden 2. KitchenAid KHM512ER Power Cord Replacement: adım 5, 3 resimden 3.
      • Firmly grip the circuit board, and using pliers, remove the black and white power cord connectors from the circuit board.
      • Some force may be required. Be careful not to cut yourself on any electrical components.
      FixBot'a Sor
      Yorum Ekle
    6. KitchenAid KHM512ER Power Cord Replacement: adım 6, 3 resimden 1. KitchenAid KHM512ER Power Cord Replacement: adım 6, 3 resimden 2. KitchenAid KHM512ER Power Cord Replacement: adım 6, 3 resimden 3.
      • Using a plastic opening tool, remove the white plastic clip on the inside of the bottom plastic piece.
      • Once it's loose, remove it with your fingers.
      • Pull the power cord through the hole.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Brad Daniels
636 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-3, Sullivan Spring 2016 USF Tampa, Team 2-3, Sullivan Spring 2016 üyesi
USFT-SULLIVAN-S16S2G3
3 Üyeler
9 adet Kılavuz yazıldı
1Rehber Yorum
where to find this cord?
Markian G.G. - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 47
Her zaman: 4,496
