Giriş
The motor is the driving force of the blender. It sits in a metal container and is surrounded by copper wire.
Neye ihtiyacın var
Remove the glass container and place the blender upside down on a solid surface.
Remove the four rubber feet using the needle nose pliers.
Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
Lift the back panel up, sliding it along the power cord.
Remove the two #5 Phillips 95 mm machine screws using the Phillips #2 screwdriver.
Remove the rubber O-ring by lifting it up.
Remove the ribbon cable from the chassis by lifting it up.
Unhook the white wire that is looped around the peg by pulling it out of the clip.
Repeat this process with the red wire on the other side of the chassis.
Remove the end cap using the 8" needle nose pliers.
Pull up the fan chassis.
Use the needle nose pliers to turn the coupling clockwise to loosen it.
Rotate the blender 90 degrees clockwise.
Remove the two #8 Phillips 12 mm screws using the Phillips #2 screwdriver.
Slide the knife in the metal loop holding the insulation before the white copper wire, and wiggle the knife back and forth until it loosens.
Pull the wire out from the metal loop that you loosened.
Bir başkası bu kılavuzu tamamladı.
