Ana içeriğe geç
KitchenAid KSB5CR Power Cable Replacement
Neye ihtiyacın var
  1. KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 1: adım 1, 3 resimden 1. KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 1: adım 1, 3 resimden 2. KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 1: adım 1, 3 resimden 3.
    • Remove the glass container and place the blender upside down on a solid surface.
    • Remove the four rubber feet using the needle nose pliers.
    • Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 2: adım 2, 1 resimden 1.
    • Lift the back panel up, sliding it along the power cord.
    FixBot'a Sor
    Yorum Ekle
  3. KitchenAid KSB5CR Power Cable Replacement, Freeing the Power Cable: adım 3, 1 resimden 1.
    • Lift up on the power cable to pop it out of its holder.
    FixBot'a Sor
    Yorum Ekle
  4. KitchenAid KSB5CR Power Cable Replacement, Detaching the White and Black Wires: adım 4, 2 resimden 1. KitchenAid KSB5CR Power Cable Replacement, Detaching the White and Black Wires: adım 4, 2 resimden 2.
    • Be gentle with the knife or you will break the circuit board.
    • Slide the knife into the metal loop holding the insulation before the white copper wire, and wiggle it back and forth until it loosens.
    • Pull the wire out from the metal loop that you loosened.
    • Repeat this process with the black copper wire.
    FixBot'a Sor
    Yorum Ekle
  5. KitchenAid KSB5CR Power Cable Replacement, Detatching the Green Wire: adım 5, 2 resimden 1. KitchenAid KSB5CR Power Cable Replacement, Detatching the Green Wire: adım 5, 2 resimden 2.
    • Using the Phillips #2 screwdriver, remove the #8 Phillips 6mm screw to which the green wire is attached.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Cameron Geehr
745 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-5, Forte Fall 2014 Cal Poly, Team 12-5, Forte Fall 2014 üyesi
CPSU-FORTE-F14S12G5
5 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 948
