Ana içeriğe geç
KitchenAid KSB5CR Ribbon Cable Replacement
Neye ihtiyacın var
  1. KitchenAid KSB5CR Ribbon Cable Replacement, Removing the Back Panel Part 1: adım 1, 3 resimden 1. KitchenAid KSB5CR Ribbon Cable Replacement, Removing the Back Panel Part 1: adım 1, 3 resimden 2. KitchenAid KSB5CR Ribbon Cable Replacement, Removing the Back Panel Part 1: adım 1, 3 resimden 3.
    • Remove the glass container and place the blender upside down on a solid surface.
    • Remove the four rubber feet using the needle nose pliers.
    • Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
  2. KitchenAid KSB5CR Ribbon Cable Replacement, Removing the Back Panel Part 2: adım 2, 1 resimden 1.
    • Lift the back panel up, sliding it along the power cord.
  3. KitchenAid KSB5CR Ribbon Cable Replacement, Removing the O-Ring: adım 3, 2 resimden 1. KitchenAid KSB5CR Ribbon Cable Replacement, Removing the O-Ring: adım 3, 2 resimden 2.
    • Remove the two #6 Hex 82mm screws using the Phillips #2 screwdriver.
    • Remove the rubber O-ring by lifting it up.
  4. KitchenAid KSB5CR Ribbon Cable Replacement, Removing the Ribbon Cable: adım 4, 1 resimden 1.
    • Remove the ribbon cable from the chassis by lifting it up.
    • Remove the other end of the ribbon cable from the circuit board by lifting it up.
Sonuç
Cameron Geehr
745 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-5, Forte Fall 2014 Cal Poly, Team 12-5, Forte Fall 2014 üyesi
CPSU-FORTE-F14S12G5
5 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 492
