Giriş
If your device is not turning on it could be because of worn down carbon brushes. Here is a guide to replace these brushes.
Neye ihtiyacın var
Using a flat head screwdriver, unscrew the brush cap on each side of the mixer by turning them counter clockwise.
Remove brush cap by pulling it toward you.
8 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
I’ve been procrastinating on trying to fix my KA mixer on my own…today I did it. The directions were pretty clear and the only thing wrong was that when I had previously cleaned my mixer, I put the carbon brushes in the wrong way. Once I shined a flashlight into the hole I could see where the notched corner went.
Unbedingt Stecker aus der Steckdose ziehen! Sollte eigentlich selbstverständlich sein, sag es aber lieber noch einmal.
Alex Atr - Yanıt
