Ana içeriğe geç
KitchenAid KSM150PSER Circuit Board Replacement
Neye ihtiyacın var
  1. KitchenAid KSM150PSER Circuit Board Replacement, Circuit Board: adım 1, 2 resimden 1. KitchenAid KSM150PSER Circuit Board Replacement, Circuit Board: adım 1, 2 resimden 2.
    • Using a Phillips #2 screwdriver, remove the 10mm screw on the back cover by rotating it counterclockwise.
    • The back cover is now free. Remove it by pulling it back and up.
    • Ensure that the mixer is disconnected from any electrical source prior to removing the back cover.
  2. KitchenAid KSM150PSER Circuit Board Replacement: adım 2, 2 resimden 1. KitchenAid KSM150PSER Circuit Board Replacement: adım 2, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove the 9.5mm screw above the circuit board by rotating it counterclockwise.
    • If you can't see the screw, try pulling the seal down past the wires to make the screw more accessible.
  3. KitchenAid KSM150PSER Circuit Board Replacement: adım 3, 2 resimden 1. KitchenAid KSM150PSER Circuit Board Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using pliers or tweezers, remove the connectors of the four wires attached to the circuit board.
  4. KitchenAid KSM150PSER Circuit Board Replacement: adım 4, 1 resimden 1.
    • Grab the wires and tilt the edge of the board up to lift the circuit board up and out.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Luke Leonard
616 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S2-G5, Livingston Winter 2018 Cal Poly, Team S2-G5, Livingston Winter 2018 üyesi
CPSU-LIVINGSTON-W18S2G5
4 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 18
Son 30 gün: 88
Her zaman: 5,976
