Ana içeriğe geç
KitchenAid KSM150PSER Power Cord Replacement
Neye ihtiyacın var
  1. KitchenAid KSM150PSER Power Cord Replacement, Power Cord: adım 1, 2 resimden 1. KitchenAid KSM150PSER Power Cord Replacement, Power Cord: adım 1, 2 resimden 2.
    • Using a Phillips #2 screwdriver, remove the 10mm screw on the back cover by rotating it counterclockwise.
    • The back cover is now free. Remove it by pulling back and up on the cover.
  2. KitchenAid KSM150PSER Power Cord Replacement: adım 2, 2 resimden 1. KitchenAid KSM150PSER Power Cord Replacement: adım 2, 2 resimden 2.
    • Using a Phillips #2 screwdriver, remove the 5mm screws holding the trimband to the top housing by rotating them counterclockwise.
    • Pull the trimband off the housing by grabbing each side and pulling it off the front.
  3. KitchenAid KSM150PSER Power Cord Replacement: adım 3, 2 resimden 1. KitchenAid KSM150PSER Power Cord Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using a Phillips #2 screwdriver, remove the 12mm screw holding the grounding wire in place by rotating it counterclockwise.
    • Using pliers or tweezers, remove the connectors attached to the white and black wires.
  4. KitchenAid KSM150PSER Power Cord Replacement: adım 4, 2 resimden 1. KitchenAid KSM150PSER Power Cord Replacement: adım 4, 2 resimden 2.
    • Using a screwdriver, pull the cord string relief out of the mixer by putting it behind the cord and pulling away from the mixer until it is free.
    • Remove the cord from the mixer body.
Sonuç
Max Prohorov
109 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S2-G5, Livingston Winter 2018 Cal Poly, Team S2-G5, Livingston Winter 2018 üyesi
CPSU-LIVINGSTON-W18S2G5
4 Üyeler
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 21
Son 30 gün: 115
Her zaman: 4,803
