Ana içeriğe geç
KitchenAid KSM150PSER Speed Control Plate Replacement
Neye ihtiyacın var
  1. KitchenAid KSM150PSER Speed Control Plate Replacement, Speed Control Plate: adım 1, 2 resimden 1. KitchenAid KSM150PSER Speed Control Plate Replacement, Speed Control Plate: adım 1, 2 resimden 2.
    • Using a Phillips #2 screwdriver, remove the 10mm screw on the back cover by rotating it counterclockwise.
    • The back cover is now free. Remove it by pulling back and up on the cover.
    FixBot'a Sor
    Yorum Ekle
  2. KitchenAid KSM150PSER Speed Control Plate Replacement: adım 2, 3 resimden 1. KitchenAid KSM150PSER Speed Control Plate Replacement: adım 2, 3 resimden 2. KitchenAid KSM150PSER Speed Control Plate Replacement: adım 2, 3 resimden 3.
    • Using a Phillips #2 screwdriver, remove the 5mm screws holding the trimband to the top housing by rotating them counterclockwise.
    • Pull the trimband off the housing by grabbing each side and pulling it off the front.
    FixBot'a Sor
    Yorum Ekle
  3. KitchenAid KSM150PSER Speed Control Plate Replacement: adım 3, 3 resimden 1. KitchenAid KSM150PSER Speed Control Plate Replacement: adım 3, 3 resimden 2. KitchenAid KSM150PSER Speed Control Plate Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Using a Phillips #2 screwdriver, remove the 12mm screw by holding the grounding wire in place and rotating it counterclockwise.
    • Using pliers or tweezers, remove the connectors attached to the speed control plate.
    FixBot'a Sor
    Yorum Ekle
  4. KitchenAid KSM150PSER Speed Control Plate Replacement: adım 4, 2 resimden 1. KitchenAid KSM150PSER Speed Control Plate Replacement: adım 4, 2 resimden 2.
    • Remove the seal from the back of the mixer. Then unhook the spring from the bottom of the speed control plate by using tweezers and pulling it back and out of the plate.
    • Take a rag or towel and hook the spring on the towel so that the hook doesn’t spring back inside the mixer.
    FixBot'a Sor
    Yorum Ekle
  5. KitchenAid KSM150PSER Speed Control Plate Replacement: adım 5, 2 resimden 1. KitchenAid KSM150PSER Speed Control Plate Replacement: adım 5, 2 resimden 2.
    • Using a Phillips #2 screwdriver, remove the two adjustment screws by rotating them counterclockwise.
    • Before beginning to remove the screws, use a ruler and measure how far the screws are in. These screws determine the speed of the mixer, and not screwing them back in to the same position will change the speed of the mixer.
    FixBot'a Sor
    Yorum Ekle
  6. KitchenAid KSM150PSER Speed Control Plate Replacement: adım 6, 1 resimden 1.
    • The control plate can now be removed by pulling back on the plate.
    FixBot'a Sor
    Yorum Ekle
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Richa Gadgil
349 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S2-G5, Livingston Winter 2018 Cal Poly, Team S2-G5, Livingston Winter 2018 üyesi
CPSU-LIVINGSTON-W18S2G5
4 Üyeler
16 adet Kılavuz yazıldı
1Rehber Yorum
Thanks for this, but a quick question, when the mixer is switched off, the metal bar on the back of the speed plate at the bottom, is that supposed to rest on the two prongs that stick out towards the bottom of the inside of the mixer? Thanks.
Mark R (dflipb) - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 41
Son 30 gün: 161
Her zaman: 24,653
