Ana içeriğe geç
KitchenAid Professional 600 Drive Motor Replacement
Neye ihtiyacın var
  1. KitchenAid Professional 600 Drive Motor Replacement, Top Cover: adım 1, 1 resimden 1.
    • Take out the screw which holds on the silver band using a Phillips #2 screwdriver.
    • Remove the silver band.
  2. KitchenAid Professional 600 Drive Motor Replacement: adım 2, 1 resimden 1.
    • Remove the four Phillips #2 screws located around the mixer where the band was removed.
    • This picture only shows two of the screw that you need to remove. The other two are on the exact opposite side of the mixer.
  3. KitchenAid Professional 600 Drive Motor Replacement: adım 3, 1 resimden 1.
    • Remove the top of the mixer to reveal the inner parts.
    • The top should lift off, but may not if it is stuck. A sharp strike from the back with the hand may unstick it. It will slide forward about a 3/8 of an inch. Push it back again from the front and it should be free enough to lift.
  4. KitchenAid Professional 600 Drive Motor Replacement, Speed Selector: adım 4, 1 resimden 1.
    • Locate the selector switch.
    • Remove the two Phillips #2 screws holding the selector switch in place.
  5. KitchenAid Professional 600 Drive Motor Replacement: adım 5, 3 resimden 1. KitchenAid Professional 600 Drive Motor Replacement: adım 5, 3 resimden 2. KitchenAid Professional 600 Drive Motor Replacement: adım 5, 3 resimden 3.
    • Unplug the cords attached the drive motor to the switch.
    • We suggest numbering them left from right so they are reattached to the replacement part in the right order.
  6. KitchenAid Professional 600 Drive Motor Replacement: adım 6, 1 resimden 1.
    • Pull out the Selector Switch.
  7. KitchenAid Professional 600 Drive Motor Replacement, Drive Motor: adım 7, 1 resimden 1.
    • Remove the two Phillips #2 screws holding the motor in place, located near the fan at the back of the motor.
    • The picture only shows one of the screws. The other screw is located on the exact opposite side of the motor.
  8. KitchenAid Professional 600 Drive Motor Replacement: adım 8, 1 resimden 1.
    • Pull upward to remove the motor.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Tallon Dotinga
487 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 25-4, Maness Spring 2016 Cal Poly, Team 25-4, Maness Spring 2016 üyesi
CPSU-MANESS-S16S25G4
4 Üyeler
20 adet Kılavuz yazıldı
4Kılavuz Yorumları
anyone know where I can get the hall effect sensor receiver that is on the motor shaft? Somehow it's missing?
Barclay Berger - Yanıt Paylaş
is there not a fusible link in series with the drive motor?
wa1shm - Yanıt Paylaş
I accidentally pluged my 110v mixer to 220v. Now, what are the possible parts that i need to change? How can i check if the motor is busted?
hyalmar planta - Yanıt Paylaş
Are the motor brushes serviceable on this model mixer and where are they located
Thanks
Gary Bell - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 48
Son 30 gün: 179
Her zaman: 15,041
