Ana içeriğe geç
KitchenAid Professional 600 Gear Housing Cover Replacement
Neye ihtiyacın var
  1. KitchenAid Professional 600 Gear Housing Cover Replacement, Top Cover: adım 1, 1 resimden 1.
    • Take out the screw which holds on the silver band using a Phillips #2 screwdriver.
    • Remove the silver band.
  2. KitchenAid Professional 600 Gear Housing Cover Replacement: adım 2, 1 resimden 1.
    • Remove the four Phillips #2 screws located around the mixer where the band was removed.
    • This picture only shows two of the screw that you need to remove. The other two are on the exact opposite side of the mixer.
  3. KitchenAid Professional 600 Gear Housing Cover Replacement: adım 3, 1 resimden 1.
    • Remove the top of the mixer to reveal the inner parts.
    • The top should lift off, but may not if it is stuck. A sharp strike from the back with the hand may unstick it. It will slide forward about a 3/8 of an inch. Push it back again from the front and it should be free enough to lift.
  4. KitchenAid Professional 600 Gear Housing Cover Replacement, Gear Housing Cover: adım 4, 1 resimden 1.
    • Remove the 4 Phillips #2 screws connecting the black housing cover to the device.
    • Only one of the screws is seen in the picture. The other three are also located around the black housing cover.
  5. KitchenAid Professional 600 Gear Housing Cover Replacement: adım 5, 1 resimden 1.
    • Take off the black housing cover.
Sonuç
Luke
1.380 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 25-4, Maness Spring 2016 Cal Poly, Team 25-4, Maness Spring 2016 üyesi
CPSU-MANESS-S16S25G4
4 Üyeler
18 adet Kılavuz yazıldı
1Rehber Yorum
I find your instructions very helpful but one of my housing pins have broken off, Can it be replaced or do I need to replace the housing? If so where do I find the housing part. I can not find it.
w.gupton - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 38
Her zaman: 3,132
