Ana içeriğe geç
KitchenAid Professional 600 Power Cord Replacement
Neye ihtiyacın var
  1. KitchenAid Professional 600 Power Cord Replacement, Top Cover: adım 1, 1 resimden 1.
    • Take out the screw which holds on the silver band using a Phillips #2 screwdriver.
    • Remove the silver band.
  2. KitchenAid Professional 600 Power Cord Replacement: adım 2, 1 resimden 1.
    • Remove the four Phillips #2 screws located around the mixer where the band was removed.
    • This picture only shows two of the screw that you need to remove. The other two are on the exact opposite side of the mixer.
  3. KitchenAid Professional 600 Power Cord Replacement: adım 3, 1 resimden 1.
    • Remove the top of the mixer to reveal the inner parts.
    • The top should lift off, but may not if it is stuck. A sharp strike from the back with the hand may unstick it. It will slide forward about a 3/8 of an inch. Push it back again from the front and it should be free enough to lift.
  4. KitchenAid Professional 600 Power Cord Replacement, Speed Selector: adım 4, 1 resimden 1.
    • Locate the selector switch.
    • Remove the two Phillips #2 screws holding the selector switch in place.
  5. KitchenAid Professional 600 Power Cord Replacement: adım 5, 3 resimden 1. KitchenAid Professional 600 Power Cord Replacement: adım 5, 3 resimden 2. KitchenAid Professional 600 Power Cord Replacement: adım 5, 3 resimden 3.
    • Unplug the cords attached the drive motor to the switch.
    • We suggest numbering them left from right so they are reattached to the replacement part in the right order.
  6. KitchenAid Professional 600 Power Cord Replacement: adım 6, 1 resimden 1.
    • Pull out the Selector Switch.
  7. KitchenAid Professional 600 Power Cord Replacement, Drive Motor: adım 7, 1 resimden 1.
    • Remove the two Phillips #2 screws holding the motor in place, located near the fan at the back of the motor.
    • The picture only shows one of the screws. The other screw is located on the exact opposite side of the motor.
  8. KitchenAid Professional 600 Power Cord Replacement: adım 8, 1 resimden 1.
    • Pull upward to remove the motor.
  9. KitchenAid Professional 600 Power Cord Replacement, Power Cord: adım 9, 1 resimden 1.
    • Remove the Phillips #2 screw attaching the green grounding wire to the frame of the mixer.
  10. KitchenAid Professional 600 Power Cord Replacement: adım 10, 1 resimden 1.
    • Remove the three Phillips #2 screws that connect the top portion of the mixer to the "neck" of the mixer.
  11. KitchenAid Professional 600 Power Cord Replacement: adım 11, 1 resimden 1.
    • Remove the top portion of the mixer from the "neck" of the mixer.
    • This will make removing the power cord much easier.
  12. KitchenAid Professional 600 Power Cord Replacement: adım 12, 1 resimden 1.
    • You can now remove the power cord from the mixer.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Luke
1.380 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 25-4, Maness Spring 2016 Cal Poly, Team 25-4, Maness Spring 2016 üyesi
CPSU-MANESS-S16S25G4
4 Üyeler
18 adet Kılavuz yazıldı
2 Yorum
So helpful thank you. I've got my mixer cord changer and the mixer is working now. Unfortunately there's always only one speed, high. Any suggestions?
Britter C - Yanıt
Any idea where I can buy the power cord itself?
Jaeger Amzallag - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 49
Her zaman: 6,277
