Ana içeriğe geç
KitchenAid Professional 600 Speed Selector Replacement
Neye ihtiyacın var
  1. KitchenAid Professional 600 Speed Selector Replacement, Top Cover: adım 1, 1 resimden 1.
    • Take out the screw which holds on the silver band using a Phillips #2 screwdriver.
    • Remove the silver band.
    Maybe start with unplugging it ?
    Ryan F - Yanıt
  2. KitchenAid Professional 600 Speed Selector Replacement: adım 2, 1 resimden 1.
    • Remove the four Phillips #2 screws located around the mixer where the band was removed.
    • This picture only shows two of the screw that you need to remove. The other two are on the exact opposite side of the mixer.
  3. KitchenAid Professional 600 Speed Selector Replacement: adım 3, 1 resimden 1.
    • Remove the top of the mixer to reveal the inner parts.
    • The top should lift off, but may not if it is stuck. A sharp strike from the back with the hand may unstick it. It will slide forward about a 3/8 of an inch. Push it back again from the front and it should be free enough to lift.
  4. KitchenAid Professional 600 Speed Selector Replacement, Speed Selector: adım 4, 1 resimden 1.
    • Locate the selector switch.
    • Remove the two Phillips #2 screws holding the selector switch in place.
  5. KitchenAid Professional 600 Speed Selector Replacement: adım 5, 3 resimden 1. KitchenAid Professional 600 Speed Selector Replacement: adım 5, 3 resimden 2. KitchenAid Professional 600 Speed Selector Replacement: adım 5, 3 resimden 3.
    • Unplug the cords attached the drive motor to the switch.
    • We suggest numbering them left from right so they are reattached to the replacement part in the right order.
    I would suggest labeling with what they go to (line, motor 1, etc) since at least for the HD version they changed the board layout so you need the labels to match them up.
    kevincash - Yanıt
  6. KitchenAid Professional 600 Speed Selector Replacement: adım 6, 1 resimden 1.
    • Pull out the Selector Switch.
    Somewhere between steps 4 and 7, you removed the planetary cover. This is just two more screws and must happen before the motor will lift out.
    Steve Muhween - Yanıt
    Oops, make that 4 more screws. Still, it's easy. Just a little gooey with the transmission grease, so mind you don't get any dirt or whatnot in there when it's open.
    Steve Muhween -
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Tallon Dotinga
487 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 25-4, Maness Spring 2016 Cal Poly, Team 25-4, Maness Spring 2016 üyesi
CPSU-MANESS-S16S25G4
4 Üyeler
18 adet Kılavuz yazıldı
8Kılavuz Yorumları
The instructions are to unplug the cords from the motor but the removed selector switch pictured shows the cords were removed from the selector switch. Is there a way to remove the cords from the selector switch without breaking them? donmilo@yahoo.com
Don Singleton - Yanıt
The replacement part looks like a major part in the mixer and probably costs a bundle like most replacement parts… sometimes deems the replacement “not worthy” to repair!
It’s like a car that cost $25K but, all its parts if you buy them separately, it will cost you $150K !!!
david almogi - Yanıt
The speed selector MSRP is $89.99 and can be found on places like eBay for $35-60. For only needing some simple tools and a little time, this fix saves you from the cost of buying a new one. These are designed to be repaired/refurbished.
Rachel Johnson -
When the speed selector is replaced, what is the rpm for “stir”?
everything is working, but it still seems too fast at 120rpm and I can’t see a difference between speeds 6, 8, & 10.
Jessica - Yanıt
The advice about kitchenaid600 switch was good. The form to get me able to say thanks was not.
What thehelldoyouwant - Yanıt
I replaced the switchbox as the machine was having difficulty starting and switching speeds and finally would not turn on at all. Plugged it in after replacing and tested and it ran 12-15 seconds and I turned it off to install the grinder attachment and turned it on, nothing. Removed the grinder attachment and turned it on, nothing.
Treacy Elliott - Yanıt
The head of my mixer fell off - there are 4 screws that replace it (some are missing so I can get some) but how do you put them in when the top is on? I'm confused.
Laurie Cancellieri - Yanıt
Most likely there is NOTHING wrong with the speed control board. You have a dirty one. When you get to step 4, pivot the board out without disconnecting anything. Remove the 4 screws that attach the plastic cover to the board and CAREFULLY remove the plastic cover. Get a spray can of contact cleaner and spray the hell out of the slider slot and the black microswitch above it. Go to town on them, particularly the switch nub on the bottom of the microswitch. put the slider to full speed and the knob to full speed and reattach the plastic cover to the board. Check to see it slides freely and clicks like it should. Reassemble the mixer and enjoy its function. The reason these fail is crud gets in the slider and switch. Contact cleaner fixes them both for less than $20 a can!
JR T - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 22
Son 30 gün: 147
Her zaman: 12,241
