Ana içeriğe geç
Kobo Arc K107 Screen Replacement
Neye ihtiyacın var
  1. Kobo Arc K107 Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Peel the back cover off of the Kobo Arc by finding the lip in the cover and pulling back on it.
  2. Kobo Arc K107 Screen Replacement: adım 2, 1 resimden 1.
    • Remove the screws from the midframe.
  3. Kobo Arc K107 Screen Replacement: adım 3, 1 resimden 1.
    • Use a nylon spudger to pry up the battery from the device.
    • It will give some resistance as it is glued down.
    • Always use plastic or nylon prying tools around the battery. Metal tools can puncture a battery, potentially causing a fire.
  4. Kobo Arc K107 Screen Replacement: adım 4, 1 resimden 1.
    • Unplug the battery connector from the rest of the tablet.
    • Remove the battery from the tablet.
  5. Kobo Arc K107 Screen Replacement, Speaker: adım 5, 2 resimden 1. Kobo Arc K107 Screen Replacement, Speaker: adım 5, 2 resimden 2.
    • Remove the screws that are attached to the grey plastic layer.
    • Remove the gray plastic layer.
  6. Kobo Arc K107 Screen Replacement: adım 6, 1 resimden 1.
    • Disconnect the speakers from the tablet.
  7. Kobo Arc K107 Screen Replacement, Screen: adım 7, 2 resimden 1. Kobo Arc K107 Screen Replacement, Screen: adım 7, 2 resimden 2.
    • Wedge a nylon spudger between the screen and the tablet.
    • Slide the spudger around the edges of the screen and remove it from the device.
Sonuç
Stephen Pehl
303 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-3, Gulbrandsen Fall 2021 UMass Dartmouth, Team 4-3, Gulbrandsen Fall 2021 üyesi
UMASSD-GULBRANDSEN-F21S4G3
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 15
Her zaman: 342
