Ana içeriğe geç
Kobo Clara HD Repairs
Neye ihtiyacın var
  1. Kobo Clara HD Repairs, Before starting: adım 1, 1 resimden 1.
    • To power off your device, hold down the power button until the "Powered off" screen appears as shown.
    FixBot'a Sor
    Yorum Ekle
  2. Kobo Clara HD Repairs, Back cover: adım 2, 3 resimden 1. Kobo Clara HD Repairs, Back cover: adım 2, 3 resimden 2. Kobo Clara HD Repairs, Back cover: adım 2, 3 resimden 3.
    • Stick a plastic spudger into the gap between the front bezel and the back cover.
    • The back cover is held on by small plastic notches.
    • Slide the spudger along the seam to release the back cover.
    • Pry all the way around until the back cover pops free.
    FixBot'a Sor
    Yorum Ekle
  3. Kobo Clara HD Repairs, Battery: adım 3, 3 resimden 1. Kobo Clara HD Repairs, Battery: adım 3, 3 resimden 2. Kobo Clara HD Repairs, Battery: adım 3, 3 resimden 3.
    • Gently pry up the white battery connector to pop it out of its bracket.
    FixBot'a Sor
    Yorum Ekle
  4. Kobo Clara HD Repairs, Screen connectors: adım 4, 3 resimden 1. Kobo Clara HD Repairs, Screen connectors: adım 4, 3 resimden 2. Kobo Clara HD Repairs, Screen connectors: adım 4, 3 resimden 3.
    • Flip up the black tabs on the three ZIF connectors to release the ribbon cables.
    • The smallest connector, under the big cable, has the black locking tab facing towards the cable.
    • Slide the ribbon cables out of the ZIF sockets.
    FixBot'a Sor
    Yorum Ekle
  5. Kobo Clara HD Repairs, Battery: adım 5, 2 resimden 1. Kobo Clara HD Repairs, Battery: adım 5, 2 resimden 2.
    • The battery is stuck down with strong double-sided tape and secured by a bracket moulded into the back cover.
    FixBot'a Sor
    Yorum Ekle
  6. Kobo Clara HD Repairs, Storage: adım 6, 2 resimden 1. Kobo Clara HD Repairs, Storage: adım 6, 2 resimden 2.
    • All the storage is on a microSD card hidden inside the device.
    • Swap it out at your own risk.
    FixBot'a Sor
    Yorum Ekle
  7. Kobo Clara HD Repairs, Logic board: adım 7, 2 resimden 1. Kobo Clara HD Repairs, Logic board: adım 7, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the 4 screws securing the logic board.
    • Lift the logic board out from the top of the device.
    • There is a black sheet of plastic that sits under the logic board.
    FixBot'a Sor
    Yorum Ekle
  8. Kobo Clara HD Repairs: adım 8, 2 resimden 1. Kobo Clara HD Repairs: adım 8, 2 resimden 2.
    • To reassemble your device, follow these steps in reverse order.
    • Pro tip: when closing the plastic housing, squeeze it shut close to the edges to avoid putting too much pressure on the display.
    FixBot'a Sor
    Yorum Ekle
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
Sparky
1.533 İtibar
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 25
Son 7 gün: 96
Son 30 gün: 422
Her zaman: 1,048
