Giriş
Use this guide to replace the front cover in your Kobo Libra Colour eReader.
The front cover consists of the plastic shell around the perimeter of the display and the two page-turn buttons.
Kobo supports their eReaders with a warranty. If your device is still under warranty, Kobo may be able to help. Before starting a repair, review your warranty information or check support documentation.
Neye ihtiyacın var
Unplug all cables and fully shut down your eReader.
Your screen should be black and say Powered off.
Flip your eReader over so the screen is facing down.
Angle an opening pick straight down, and insert its tip under the top right corner of the back cover, near the power button.
Push downward and pry up with the pick until you feel it slide between one of the clips and the frame.
Slide the pick toward the bottom right corner to release the clips along the right edge.
Slide the pick toward the bottom left corner to release the clips along the bottom edge.
Grip the right edge of the back cover and lift it away from the eReader to release the remaining clips.
Remove the back cover.
The coating is brittle and can flake into many small pieces. Heating the coating helps, but working with it is still a time-consuming process.
Depending on your repair, you might have to remove the coating from ZIF connectors and their cables.
Use a spudger to pry up and disconnect the battery press connector.
Use a Phillips screwdriver to remove the two 3.9 mm‑long screws securing the front cover.
The front cover is secured with clips and adhesive.
Flip your eReader over so the screen is facing up.
Heat an iOpener and lay it on the top edge of the front cover for 90 seconds to soften the adhesive underneath.
Hold the eReader so your thumbs can push the underside of the front cover off its clips while your other fingers can pull the screen in the opposite direction.
Push the top left corner of the front cover while pulling the screen in the opposite direction to release the clips and separate the adhesive.
Lift the front cover off the screen and remove it.
If your replacement front cover comes with pre‑installed adhesive, remove the liner. Otherwise, use a thin double-sided tape like Tesa tape to replace the adhesive.
Align the front cover over the frame and press down around the perimeter until the clips snap back into place.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Make sure each of your device's main functions still work, e.g., LED backlight, touch, page-turn buttons, Wi-Fi, etc.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Bir başkası bu kılavuzu tamamladı.
