Giriş
This guide will help you fix a problem where the battery connection comes loose causing the Kobe Vox to not boot
You can also use this guide to replace the battery entirely.
Neye ihtiyacın var
To reassemble your device, follow these instructions in reverse order. All you have to do is snap in the back cover.
6 farklı kişi bu kılavuzu tamamladı.
