Giriş
This guide shows you how to replace the motor of your Kobold VK150 vacuum cleaner. The motor is an essential part of the vacuum cleaner and a defective motor can cause the appliance to stop working.
***Why this repair?
It may be necessary to replace the motor if the vacuum cleaner no longer has any suction power, makes unusual noises or can no longer be switched on at all. This repair will extend the life of your vacuum cleaner and save you money as you won't have to buy a new one.
Safety instructions:
- Make sure that the vacuum cleaner is disconnected from the power supply before you start the repair.
- It is best to wear protective gloves to avoid injury.
- Be sure to handle the parts carefully to avoid damage.
Neye ihtiyacın var
Use a TX10 screwdriver
Remove the housing screws on the rear of the device.
6 long screws
3 short screws
Place the device with the white lid facing up.
Start to carefully lift the lid at the front of the suction nozzle. Slowly work your way up to the stem.
Now you can lift the flap of the vacuum cleaner bag. This was only held by the white lid.
Disconnect the power supply connector by pressing the unlocking lever.
Unplug the motherboard connector.
Put the cable aside
Unlock and loosen the rotary switch plug.
Disconnect the white air hose from the intake manifold.
Release 2 plastic clips
Remove the wiring harness with the plastic holder.
Remove the motor and main board assembly from the housing.
Remove the foam
Stand the motor with the main circuit board upright .
Align the motor shaft by turning it so that the lamella of the speedometer is in the area of the orange square.
Slightly push on the black plastic connector. The connector should come off easily
Use a levering tool to loosen the clips on the motor mount.
Top part o the motor casing can now be removed
Bu çevirmenlere özel teşekkürler:
100%
oldturkey03 dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
8 Yorum
Moin ! Ich habe das Problem das der Motor nach dem Tausch nur 5x klackert - er springt danach leider nicht mehr an. Hast du noch eine Idee?
Ich habe Motor + Platine getauscht.
Hallo Ich hab das gleiche Problem, wie habt ihr das gelöst ?
Grüße Andrea
A. G.-H. -
Hallo, habe ebenfalls das "Summen und Klackern " nach dem Einschalten. Gibt es dazu vielleicht eine brauchbare Lösung? Im Elektronikforum beschreiben mehrere User dieses Symptom, wobei eine mögliche Abhilfe ein Austausch eines Eingangsspannungs Kondensator am Netzteil sein könnte?
Original Kommentar:
Vermutung:
Die Spannungsversorgung der Elektronik erfolgt über ein sog. Kondensatornetzteil, das heißt, ein Kondensator ist in Reihe mit der Netzspannung geschaltet und reduziert die Eingangsspannung für die Elektronik. Wenn dieser Kondensator Kapazität verliert, wird auch die Versorgungsspannung für die Elektronik zu niedrig.
Hallo,
habe ebenso das Summen und Klacken (auf Stufe drei gut hörbar). Der Motor scheint anlaufen zu wollen, es macht aber den Eindruck das er klemmt. Gibt es bereits eine Lösung? Vielen Dank euch
Susi -
Moin, und Funktioniert es bei dir wider?
ich habe das gleiche Problem und komme noch nicht weiter.
