Ana içeriğe geç
Kocaso M750B Screen Replacement
Neye ihtiyacın var
  1. Kocaso M750B Screen Replacement, Backplate: adım 1, 3 resimden 1. Kocaso M750B Screen Replacement, Backplate: adım 1, 3 resimden 2. Kocaso M750B Screen Replacement, Backplate: adım 1, 3 resimden 3.
    • Pry the edges of the tablet apart using an iFixit opening tool.
  2. Kocaso M750B Screen Replacement, Display: adım 2, 2 resimden 1. Kocaso M750B Screen Replacement, Display: adım 2, 2 resimden 2.
    • Remove three 1.2 mm screws from the motherboard using a Phillips #000 screwdriver.
  3. Kocaso M750B Screen Replacement: adım 3, 1 resimden 1.
    • Disconnect the ribbon cables.
    • This guide will help you identify what type of ribbon cables the tablet uses and helps you on how exactly to remove different types of ribbon cables. The exact ribbon cables you are looking for are called ZIF connectors.
  4. Kocaso M750B Screen Replacement: adım 4, 1 resimden 1.
    • Desolder the connections to the motherboard and the display.
    • When using the soldering iron, make sure to review the safety guidelines provided in the introduction. Work carefully and precisely to avoid any electrical discharge, puncture of the battery, or heating of the motherboard.
  5. Kocaso M750B Screen Replacement: adım 5, 2 resimden 1. Kocaso M750B Screen Replacement: adım 5, 2 resimden 2.
    • Remove the display by loosening the tabs surrounding it.
  6. Kocaso M750B Screen Replacement, Screen: adım 6, 1 resimden 1.
    • You now have independent access to the tablet's screen.
Sonuç
Syeda Anosha Ali
399 İtibar
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 22
Her zaman: 80
