Giriş
This guide will show you how to remove the internal lens of your camera.
Neye ihtiyacın var
To start, remove the Philips #00 4.5 mm screws on both sides of the camera.
On the bottom, there are three Philips #00 4.5 mm screws. Two are for the front panel and one is for the back panel. To remove the back panel, take out the screws indicated in the final picture of the sequence.
Now that the LCD screen as been completely removed, the internal lens can be removed.
To do this, flip the two black tabs to the left of the yellow motherboard up.
2 farklı kişi bu kılavuzu tamamladı.
