Ana içeriğe geç
Kodak EasyShare C713 Battery Door Replacement
Neye ihtiyacın var
  1. Kodak EasyShare C713 Battery Door Replacement, Batteries: adım 1, 1 resimden 1.
    • Use your finger tip to slide battery cover door away from the center of the camera.
    • The battery door should spring open.
    • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
  2. Kodak EasyShare C713 Battery Door Replacement: adım 2, 1 resimden 1.
    • Remove the old batteries.
  3. Kodak EasyShare C713 Battery Door Replacement, Outer Case: adım 3, 3 resimden 1. Kodak EasyShare C713 Battery Door Replacement, Outer Case: adım 3, 3 resimden 2. Kodak EasyShare C713 Battery Door Replacement, Outer Case: adım 3, 3 resimden 3.
    • Remove the seven screws from the outer case with a Phillips #00.
    • All screws are 4.45mm.
    • There are 2 screws on the port side.
    • There are 2 screws on starboard side.
    • There are 3 screws on the bottom.
  4. Kodak EasyShare C713 Battery Door Replacement: adım 4, 3 resimden 1. Kodak EasyShare C713 Battery Door Replacement: adım 4, 3 resimden 2. Kodak EasyShare C713 Battery Door Replacement: adım 4, 3 resimden 3.
    • Make sure the battery cap is "up".
    • Pull the outer case off with your hands.
  5. Kodak EasyShare C713 Battery Door Replacement, Battery Door: adım 5, 2 resimden 1. Kodak EasyShare C713 Battery Door Replacement, Battery Door: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Make sure the battery door is open.
    • Using a pair of tweezers, remove the metal rod at the junction of the battery door and the inner camera case.
    • This rod serves as the hinge for the door.
    • Make sure not to lose the battery door spring which may fall when the rod is removed.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Trevor DeVore
17 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 26-19, Regan Spring 2010 Cal Poly, Team 26-19, Regan Spring 2010 üyesi
CPSU-REGAN-S10S26G19
4 Üyeler
14 adet Kılavuz yazıldı
Bir Yorum
Where do I buy a new battery door. Cheers, Peter
Peter - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 22
Her zaman: 5,219
