Giriş
Replacing the camera buttons.
Parçalar
Hiçbir parçaya gerek yok.
  1. Use your finger tip to slide battery cover door away from the center of the camera.
    • Use your finger tip to slide battery cover door away from the center of the camera.
    • The battery door should spring open.
    • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
  2. Remove the old batteries.
    • Remove the old batteries.
  3. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  4. Remove 7 screws from the outer case with a Phillips #00. All screws are 4.45mm. There are 2 screws on the port side.
    • Remove 7 screws from the outer case with a Phillips #00.
    • All screws are 4.45mm.
    • There are 2 screws on the port side.
    • There are 2 screws on starboard side.
    • There are 3 screws on the bottom.
  5. Make sure the battery cap is "up". Pull the outer case off with your hands. Pull the outer case off with your hands.
    • Make sure the battery cap is "up".
    • Pull the outer case off with your hands.
  6. Remove the necessary broken buttons.
    • Remove the necessary broken buttons.
    • They come out easily so just use your fingers.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Taggart Ashby
315 İtibar
4 adet Kılavuz yazıldı
Takım
Cal Poly, Team 26-19, Regan Spring 2010 Cal Poly, Team 26-19, Regan Spring 2010 üyesi
CPSU-REGAN-S10S26G19
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 3
Her zaman: 2,579
