Giriş
Replacing the capacitor.
Neye ihtiyacın var
Use your finger tip to slide battery cover door away from the center of the camera.
The battery door should spring open.
If this does not happen, gently open the door lifting from the outer bottom side of the camera.
Remove the seven screws from the outer case with a Phillips #00.
All screws are 4.45mm.
There are 2 screws on the port side.
There are 2 screws on starboard side.
There are 3 screws on the bottom.
The capacitor is located underneath the lens.
It is held in place by 4 plastic snaps; it can be easily removed by pulling outward with your fingers.
2 farklı kişi bu kılavuzu tamamladı.
