Giriş
Removing and replacing the LCD and LCD casing.
Neye ihtiyacın var
Use your finger tip to slide battery cover door away from the center of the camera.
The battery door should spring open.
If this does not happen, gently open the door lifting from the outer bottom side of the camera.
Remove the seven screws from the outer case with a Phillips #00.
All screws are 4.45mm.
There are 2 screws on the port side.
There are 2 screws on starboard side.
There are 3 screws on the bottom.
Put your thumb in the upper right corner of the LCD screen.
Pull the LCD screen out of its outer case with your thumb.
6 farklı kişi bu kılavuzu tamamladı.
2 Yorum
hvor kan jeg kjøpe LCD skjermen til dette kamerat, og hva koster et sånn LCD-skjerm
