Ana içeriğe geç
Kodak EasyShare C713 LCD Replacement
Neye ihtiyacın var
  1. Kodak EasyShare C713 LCD Replacement, Batteries: adım 1, 1 resimden 1.
    • Use your finger tip to slide battery cover door away from the center of the camera.
    • The battery door should spring open.
    • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
  2. Kodak EasyShare C713 LCD Replacement: adım 2, 1 resimden 1.
    • Remove the old batteries.
  3. Kodak EasyShare C713 LCD Replacement, Outer Case: adım 3, 3 resimden 1. Kodak EasyShare C713 LCD Replacement, Outer Case: adım 3, 3 resimden 2. Kodak EasyShare C713 LCD Replacement, Outer Case: adım 3, 3 resimden 3.
    • Remove the seven screws from the outer case with a Phillips #00.
    • All screws are 4.45mm.
    • There are 2 screws on the port side.
    • There are 2 screws on starboard side.
    • There are 3 screws on the bottom.
  4. Kodak EasyShare C713 LCD Replacement: adım 4, 3 resimden 1. Kodak EasyShare C713 LCD Replacement: adım 4, 3 resimden 2. Kodak EasyShare C713 LCD Replacement: adım 4, 3 resimden 3.
    • Make sure the battery cap is "up".
    • Pull the outer case off with your hands.
  5. Kodak EasyShare C713 LCD Replacement, LCD: adım 5, 1 resimden 1.
    • The LCD screen is hinged at the bottom.
    • Put your thumb in the upper right corner of the LCD screen.
    • Pull the LCD screen out of its outer case with your thumb.
  6. Kodak EasyShare C713 LCD Replacement: adım 6, 1 resimden 1.
    • Remove the screw underneath LCD screen with the Phillips #00. The screw measures 4.1mm in length.
  7. Kodak EasyShare C713 LCD Replacement: adım 7, 2 resimden 1. Kodak EasyShare C713 LCD Replacement: adım 7, 2 resimden 2.
    • Desolder the two points.
    • One on the port side.
    • One on the bottom.
  8. Kodak EasyShare C713 LCD Replacement: adım 8, 1 resimden 1.
    • After desoldering the LCD casing, just use your fingers to carefully remove it.
  9. Kodak EasyShare C713 LCD Replacement: adım 9, 1 resimden 1.
    • Flip up the black tab on the bottom of the LCD screen with a fingertip.
  10. Kodak EasyShare C713 LCD Replacement: adım 10, 1 resimden 1.
    • Remove the LCD ribbon cable from inside the black tab.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Taggart Ashby
354 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 26-19, Regan Spring 2010 Cal Poly, Team 26-19, Regan Spring 2010 üyesi
CPSU-REGAN-S10S26G19
4 Üyeler
14 adet Kılavuz yazıldı
2 Yorum
Thank you... i fixed my old camera lcd.
anthoxman - Yanıt
hvor kan jeg kjøpe LCD skjermen til dette kamerat, og hva koster et sånn LCD-skjerm
fancy tassen - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 32
Her zaman: 5,324
