Ana içeriğe geç
Kodak EasyShare C713 Lens Replacement
Neye ihtiyacın var
    1. Kodak EasyShare C713 Lens Replacement, Batteries: adım 1, 1 resimden 1.
      • Use your finger tip to slide battery cover door away from the center of the camera.
      • The battery door should spring open.
      • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
      FixBot'a Sor
      Yorum Ekle
    2. Kodak EasyShare C713 Lens Replacement: adım 2, 1 resimden 1.
      • Remove the old batteries.
      FixBot'a Sor
      Yorum Ekle
    1. Kodak EasyShare C713 Lens Replacement, Outer Case: adım 3, 3 resimden 1. Kodak EasyShare C713 Lens Replacement, Outer Case: adım 3, 3 resimden 2. Kodak EasyShare C713 Lens Replacement, Outer Case: adım 3, 3 resimden 3.
      • Remove the seven screws from the outer case with a Phillips #00.
      • All screws are 4.45mm.
      • There are 2 screws on the port side.
      • There are 2 screws on starboard side.
      • There are 3 screws on the bottom.
      FixBot'a Sor
      Yorum Ekle
    2. Kodak EasyShare C713 Lens Replacement: adım 4, 3 resimden 1. Kodak EasyShare C713 Lens Replacement: adım 4, 3 resimden 2. Kodak EasyShare C713 Lens Replacement: adım 4, 3 resimden 3.
      • Make sure the battery cap is "up".
      • Pull the outer case off with your hands.
      FixBot'a Sor
      Yorum Ekle
    1. Kodak EasyShare C713 Lens Replacement, LCD: adım 5, 1 resimden 1.
      • The LCD screen is hinged at the bottom.
      • Put your thumb in the upper right corner of the LCD screen.
      • Pull the LCD screen out of its outer case with your thumb.
      FixBot'a Sor
      Yorum Ekle
    2. Kodak EasyShare C713 Lens Replacement: adım 6, 1 resimden 1.
      • Remove the screw underneath LCD screen with the Phillips #00. The screw measures 4.1mm in length.
      FixBot'a Sor
      Yorum Ekle
    3. Kodak EasyShare C713 Lens Replacement: adım 7, 2 resimden 1. Kodak EasyShare C713 Lens Replacement: adım 7, 2 resimden 2.
      • Desolder the two points.
      • One on the port side.
      • One on the bottom.
      FixBot'a Sor
      Yorum Ekle
    4. Kodak EasyShare C713 Lens Replacement: adım 8, 1 resimden 1.
      • After desoldering the LCD casing, just use your fingers to carefully remove it.
      FixBot'a Sor
      Yorum Ekle
    5. Kodak EasyShare C713 Lens Replacement: adım 9, 1 resimden 1.
      • Flip up the black tab on the bottom of the LCD screen with a fingertip.
      FixBot'a Sor
      Yorum Ekle
    6. Kodak EasyShare C713 Lens Replacement: adım 10, 1 resimden 1.
      • Remove the LCD ribbon cable from inside the black tab.
      FixBot'a Sor
      Yorum Ekle
    1. Kodak EasyShare C713 Lens Replacement, Lens: adım 11, 1 resimden 1.
      • Using a fingertip, flip the black tab near the top of the camera.
      • Remove the ribbon connector from inside the black tab.
      FixBot'a Sor
      Yorum Ekle
    2. Kodak EasyShare C713 Lens Replacement: adım 12, 1 resimden 1.
      • Remove the remaining eight 4.1mm screws on the back with the Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Kodak EasyShare C713 Lens Replacement: adım 13, 1 resimden 1.
      • Desolder the upper points.
      • There is a series of solder points in a rectangular area in the upper middle of the camera.
      • There is a large solder point in the upper right.
      FixBot'a Sor
      Yorum Ekle
    4. Kodak EasyShare C713 Lens Replacement: adım 14, 1 resimden 1.
      • Turn the camera over.
      • Remove the silver 2.2mm battery cap screw.
      FixBot'a Sor
      Yorum Ekle
    5. Kodak EasyShare C713 Lens Replacement: adım 15, 2 resimden 1. Kodak EasyShare C713 Lens Replacement: adım 15, 2 resimden 2.
      • Pry the capacitor out of its holder on the bottom of the camera with your fingers.
      FixBot'a Sor
      Yorum Ekle
    6. Kodak EasyShare C713 Lens Replacement: adım 16, 3 resimden 1. Kodak EasyShare C713 Lens Replacement: adım 16, 3 resimden 2. Kodak EasyShare C713 Lens Replacement: adım 16, 3 resimden 3.
      • Remove the lens assembly with your fingers.
      • You may need to wiggle it back and forth until it comes loose.
      • Do not touch the marked areas. This will cause the camera to take blurry pictures.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Taggart Ashby
360 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 26-19, Regan Spring 2010 Cal Poly, Team 26-19, Regan Spring 2010 üyesi
CPSU-REGAN-S10S26G19
4 Üyeler
14 adet Kılavuz yazıldı
1Rehber Yorum
why didn't you mention to discharge the capacitor, its stored charge is pretty high & dangerous
richard - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 46
Her zaman: 7,866
