Ana içeriğe geç
Kodak EasyShare C913 Buttons Replacement
Neye ihtiyacın var
  1. Kodak EasyShare C913 Buttons Replacement, Batteries: adım 1, 3 resimden 1. Kodak EasyShare C913 Buttons Replacement, Batteries: adım 1, 3 resimden 2. Kodak EasyShare C913 Buttons Replacement, Batteries: adım 1, 3 resimden 3.
    • Position the camera with the bottom facing up.
    • Slide the battery cover in the direction of the arrow with your finger gently.
    • Remove the batteries
  2. Kodak EasyShare C913 Buttons Replacement, Back Case: adım 2, 3 resimden 1. Kodak EasyShare C913 Buttons Replacement, Back Case: adım 2, 3 resimden 2. Kodak EasyShare C913 Buttons Replacement, Back Case: adım 2, 3 resimden 3.
    • Remove the seven 4.5mm screws with a Phillips #00 screwdriver.
    • 2 on the left
    • 2 on the right
    • 3 on the bottom
  3. Kodak EasyShare C913 Buttons Replacement: adım 3, 3 resimden 1. Kodak EasyShare C913 Buttons Replacement: adım 3, 3 resimden 2. Kodak EasyShare C913 Buttons Replacement: adım 3, 3 resimden 3.
    • Firmly grasp the back of the camera and pull the away the casing.
  4. Kodak EasyShare C913 Buttons Replacement, Buttons: adım 4, 3 resimden 1. Kodak EasyShare C913 Buttons Replacement, Buttons: adım 4, 3 resimden 2. Kodak EasyShare C913 Buttons Replacement, Buttons: adım 4, 3 resimden 3.
    • Use #00 screwdriver to pry off buttons.
Sonuç
Alan Galarza
72 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-51, Amido Fall 2010 Cal Poly, Team 7-51, Amido Fall 2010 üyesi
CPSU-AMIDO-F10S7G51
4 Üyeler
14 adet Kılavuz yazıldı
Bir Yorum
Thank you this was very helpful!
carolnelson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 1,334
