Ana içeriğe geç
Kodak EasyShare C913 Capacitor Replacement
Neye ihtiyacın var
    1. Kodak EasyShare C913 Capacitor Replacement, Batteries: adım 1, 3 resimden 1. Kodak EasyShare C913 Capacitor Replacement, Batteries: adım 1, 3 resimden 2. Kodak EasyShare C913 Capacitor Replacement, Batteries: adım 1, 3 resimden 3.
      • Position the camera with the bottom facing up.
      • Slide the battery cover in the direction of the arrow with your finger gently.
      • Remove the batteries
      FixBot'a Sor
      Yorum Ekle
    1. Kodak EasyShare C913 Capacitor Replacement, Back Case: adım 2, 3 resimden 1. Kodak EasyShare C913 Capacitor Replacement, Back Case: adım 2, 3 resimden 2. Kodak EasyShare C913 Capacitor Replacement, Back Case: adım 2, 3 resimden 3.
      • Remove the seven 4.5mm screws with a Phillips #00 screwdriver.
      • 2 screws on the left, 2 screws on the right, 3 screws on the bottom
      FixBot'a Sor
      Yorum Ekle
    2. Kodak EasyShare C913 Capacitor Replacement: adım 3, 3 resimden 1. Kodak EasyShare C913 Capacitor Replacement: adım 3, 3 resimden 2. Kodak EasyShare C913 Capacitor Replacement: adım 3, 3 resimden 3.
      • Firmly grasp the back of the camera and pull the casing away.
      FixBot'a Sor
      Yorum Ekle
    1. Kodak EasyShare C913 Capacitor Replacement, Front Case: adım 4, 3 resimden 1. Kodak EasyShare C913 Capacitor Replacement, Front Case: adım 4, 3 resimden 2. Kodak EasyShare C913 Capacitor Replacement, Front Case: adım 4, 3 resimden 3.
      • Keep the battery door open
      • Firmly grasp the front casing and pull it away from the camera.
      FixBot'a Sor
      Yorum Ekle
    1. Kodak EasyShare C913 Capacitor Replacement, Capacitor: adım 5, 2 resimden 1. Kodak EasyShare C913 Capacitor Replacement, Capacitor: adım 5, 2 resimden 2.
      • Orient the camera with the lens facing you.
      • Use a Phillips #00 screwdriver to remove the one 2.2mm screw on the plastic bridge.
      • Lift the plastic bridge off and place it to the side.
      FixBot'a Sor
      Yorum Ekle
    2. Kodak EasyShare C913 Capacitor Replacement: adım 6, 1 resimden 1.
      • Do not touch the capacitor contact points for any reason. This will result in a severe shock.
      FixBot'a Sor
      Yorum Ekle
    3. Kodak EasyShare C913 Capacitor Replacement: adım 7, 3 resimden 1. Kodak EasyShare C913 Capacitor Replacement: adım 7, 3 resimden 2. Kodak EasyShare C913 Capacitor Replacement: adım 7, 3 resimden 3.
      • Grasp the capacitor, carefully remove it from its holder, and place it off to the side.
      FixBot'a Sor
      Yorum Ekle
    4. Kodak EasyShare C913 Capacitor Replacement: adım 8, 1 resimden 1.
      • De-solder the connections at the base of the capacitor
      FixBot'a Sor
      Yorum Ekle
Sonuç
Alan Galarza
84 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-51, Amido Fall 2010 Cal Poly, Team 7-51, Amido Fall 2010 üyesi
CPSU-AMIDO-F10S7G51
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 43
Her zaman: 4,697
