Ana içeriğe geç
Kodak EasyShare C913 Capacitor Replacement
Neye ihtiyacın var
  1. Kodak EasyShare C913 Capacitor Replacement, Batteries: adım 1, 3 resimden 1. Kodak EasyShare C913 Capacitor Replacement, Batteries: adım 1, 3 resimden 2. Kodak EasyShare C913 Capacitor Replacement, Batteries: adım 1, 3 resimden 3.
    • Position the camera with the bottom facing up.
    • Slide the battery cover in the direction of the arrow with your finger gently.
    • Remove the batteries
  2. Kodak EasyShare C913 Capacitor Replacement, Back Case: adım 2, 3 resimden 1. Kodak EasyShare C913 Capacitor Replacement, Back Case: adım 2, 3 resimden 2. Kodak EasyShare C913 Capacitor Replacement, Back Case: adım 2, 3 resimden 3.
    • Remove the seven 4.5mm screws with a Phillips #00 screwdriver.
    • 2 on the left
    • 2 on the right
    • 3 on the bottom
  3. Kodak EasyShare C913 Capacitor Replacement: adım 3, 3 resimden 1. Kodak EasyShare C913 Capacitor Replacement: adım 3, 3 resimden 2. Kodak EasyShare C913 Capacitor Replacement: adım 3, 3 resimden 3.
    • Firmly grasp the back of the camera and pull the away the casing.
  4. Kodak EasyShare C913 Capacitor Replacement, Front Case: adım 4, 3 resimden 1. Kodak EasyShare C913 Capacitor Replacement, Front Case: adım 4, 3 resimden 2. Kodak EasyShare C913 Capacitor Replacement, Front Case: adım 4, 3 resimden 3.
    • Keep the battery door open
    • Firmly grasp the front casing and pull away from the camera.
  5. Kodak EasyShare C913 Capacitor Replacement, Capacitor: adım 5, 2 resimden 1. Kodak EasyShare C913 Capacitor Replacement, Capacitor: adım 5, 2 resimden 2.
    • Orient the camera with the lens facing you.
    • Use a Phillips #00 screwdriver to remove the one 2.2mm screw on the plastic bridge.
    • Lift the plastic bridge off and place it to the side.
  6. Kodak EasyShare C913 Capacitor Replacement: adım 6, 1 resimden 1.
    • Do not touch the capacitor contact points for any reason. This will result in a severe shock.
  7. Kodak EasyShare C913 Capacitor Replacement: adım 7, 3 resimden 1. Kodak EasyShare C913 Capacitor Replacement: adım 7, 3 resimden 2. Kodak EasyShare C913 Capacitor Replacement: adım 7, 3 resimden 3.
    • Grasp the capacitor, carefully remove it from its holder, and place it off to the side.
  8. Kodak EasyShare C913 Capacitor Replacement: adım 8, 1 resimden 1.
    • De-solder the connections at the base of the capacitor
Sonuç
Alan Galarza
72 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-51, Amido Fall 2010 Cal Poly, Team 7-51, Amido Fall 2010 üyesi
CPSU-AMIDO-F10S7G51
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 3,995
