Ana içeriğe geç
Kodak EasyShare C913 Front Case Replacement
Neye ihtiyacın var
  1. Kodak EasyShare C913 Front Case Replacement, Batteries: adım 1, 3 resimden 1. Kodak EasyShare C913 Front Case Replacement, Batteries: adım 1, 3 resimden 2. Kodak EasyShare C913 Front Case Replacement, Batteries: adım 1, 3 resimden 3.
    • Position the camera with the bottom facing up.
    • Slide the battery cover in the direction of the arrow with your finger gently.
    • Remove the batteries
  2. Kodak EasyShare C913 Front Case Replacement, Back Case: adım 2, 3 resimden 1. Kodak EasyShare C913 Front Case Replacement, Back Case: adım 2, 3 resimden 2. Kodak EasyShare C913 Front Case Replacement, Back Case: adım 2, 3 resimden 3.
    • Remove the seven 4.5mm screws with a Phillips #00 screwdriver.
    • 2 on the left
    • 2 on the right
    • 3 on the bottom
  3. Kodak EasyShare C913 Front Case Replacement: adım 3, 3 resimden 1. Kodak EasyShare C913 Front Case Replacement: adım 3, 3 resimden 2. Kodak EasyShare C913 Front Case Replacement: adım 3, 3 resimden 3.
    • Firmly grasp the back of the camera and pull the away the casing.
  4. Kodak EasyShare C913 Front Case Replacement, Front Case: adım 4, 3 resimden 1. Kodak EasyShare C913 Front Case Replacement, Front Case: adım 4, 3 resimden 2. Kodak EasyShare C913 Front Case Replacement, Front Case: adım 4, 3 resimden 3.
    • Keep the battery door open
    • Firmly grasp the front casing and pull away from the camera.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Dustin Rodgers
65 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-51, Amido Fall 2010 Cal Poly, Team 7-51, Amido Fall 2010 üyesi
CPSU-AMIDO-F10S7G51
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 2,996
