Ana içeriğe geç
Kodak EasyShare CD82 Lens Assembly Replacement
Neye ihtiyacın var
  1. Kodak EasyShare CD82 Lens Assembly Replacement, Lens Assembly: adım 1, 3 resimden 1. Kodak EasyShare CD82 Lens Assembly Replacement, Lens Assembly: adım 1, 3 resimden 2. Kodak EasyShare CD82 Lens Assembly Replacement, Lens Assembly: adım 1, 3 resimden 3.
    • Remove the batteries and the memory card from the device.
    • Remove the two screws located at the bottom of the camera.
  2. Kodak EasyShare CD82 Lens Assembly Replacement: adım 2, 3 resimden 1. Kodak EasyShare CD82 Lens Assembly Replacement: adım 2, 3 resimden 2. Kodak EasyShare CD82 Lens Assembly Replacement: adım 2, 3 resimden 3.
    • Remove the two screws on the side of the device, to left of the camera lens.
    • Remove the two screws on side of the device, to the right of the camera lens.
    • Pry the casing apart at the seems, starting at the battery compartment.
  3. Kodak EasyShare CD82 Lens Assembly Replacement: adım 3, 3 resimden 1. Kodak EasyShare CD82 Lens Assembly Replacement: adım 3, 3 resimden 2. Kodak EasyShare CD82 Lens Assembly Replacement: adım 3, 3 resimden 3.
    • Remove the front casing from the mid-frame, first.
    • Continue to remove the back casing from the mid-frame.
    • Do not remove the LCD screen from the device once it becomes visible.
  4. Kodak EasyShare CD82 Lens Assembly Replacement: adım 4, 3 resimden 1. Kodak EasyShare CD82 Lens Assembly Replacement: adım 4, 3 resimden 2. Kodak EasyShare CD82 Lens Assembly Replacement: adım 4, 3 resimden 3.
    • Flip the LCD screen out of the holder from the top to reveal ribbon cable.
    • This camera had some obvious water damage..
    • Remove the three screws from the LCD holder
    • Dislodge the LCD screen holder from the circuit board connector.
  5. Kodak EasyShare CD82 Lens Assembly Replacement: adım 5, 3 resimden 1. Kodak EasyShare CD82 Lens Assembly Replacement: adım 5, 3 resimden 2. Kodak EasyShare CD82 Lens Assembly Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Disconnect the logic board from the frame on the right side of the device.
    • Remove the small ribbon cable, connecting the button board to the logic board, with small pair of tweezers or hemostat.
    • Remove the screw on the top right side of the device connecting the LCD screen holder to the midframe.
    • Move the black clip into the upward position to disconnect the cable.
    • You will now be able to remove the LCD screen and its holder from the device.
  6. Kodak EasyShare CD82 Lens Assembly Replacement: adım 6, 3 resimden 1. Kodak EasyShare CD82 Lens Assembly Replacement: adım 6, 3 resimden 2. Kodak EasyShare CD82 Lens Assembly Replacement: adım 6, 3 resimden 3.
    • Flip the black clips of the connectors into the opposite direction. Remove the lens and CCD cable.
    • Remove the two screws securing the lens to the midframe.
    • These are missing screws for the CCD sensor, lost in a previous dismantling.
    • Remove the single screw securing the lens to the mid-frame. The lens will now be loose.
    • Push the lens out of the frame in an angular direction, and remove.
  7. Kodak EasyShare CD82 Lens Assembly Replacement: adım 7, 1 resimden 1.
    • Insert the new lens the same way it was removed.
    • Clean and reassemble the camera.
Sonuç
Bir başkası bu kılavuzu tamamladı.
oldturkey03
814.130 İtibar
119 adet Kılavuz yazıldı
Ekip
Global Fixers Global Fixers üyesi
Community
45 Üyeler
704 adet Kılavuz yazıldı
1Rehber Yorum
When it says "Dislodge the LCD screen holder from the circuit board connector" does it mean that I can break that solder without desoldering and it's okay?
Sith Siri - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 1,777
