Ana içeriğe geç
Kodak EasyShare LS743 Camera Case Disassembly
Neye ihtiyacın var
  1. Kodak EasyShare LS743 Camera Case Disassembly, Kodak EasyShare LS743 Camera Case Disassembly: adım 1, 3 resimden 1. Kodak EasyShare LS743 Camera Case Disassembly, Kodak EasyShare LS743 Camera Case Disassembly: adım 1, 3 resimden 2. Kodak EasyShare LS743 Camera Case Disassembly, Kodak EasyShare LS743 Camera Case Disassembly: adım 1, 3 resimden 3.
    • Using a Phillips #00 screwdriver, remove two 5.39 mm screws next to the battery slot.
    • Remove the metal piece holding down the lanyard, then remove the lanyard.
  2. Kodak EasyShare LS743 Camera Case Disassembly: adım 2, 3 resimden 1. Kodak EasyShare LS743 Camera Case Disassembly: adım 2, 3 resimden 2. Kodak EasyShare LS743 Camera Case Disassembly: adım 2, 3 resimden 3.
    • Using a Phillips #00 screwdriver, remove seven screws located on the outside case of the camera.
    • One 6.25 mm screw is located on the top right corner, right to the "OK" button.
    • Four 4.45 mm screws are on the bottom of the camera.
    • Two 2.95 mm screws are on the left side of the camera, above the USB port.
  3. Kodak EasyShare LS743 Camera Case Disassembly: adım 3, 2 resimden 1. Kodak EasyShare LS743 Camera Case Disassembly: adım 3, 2 resimden 2.
    • Carefully remove the rear camera casing.
    • Carefully remove the front camera casing.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Michael
63 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-8, Johann Summer 2010 Cal Poly, Team 2-8, Johann Summer 2010 üyesi
CPSU-JOHANN-R10S2G8
5 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 19
Her zaman: 2,075
